Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
ptuga
Re: Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
Post by ptuga » 10 Jun 2020, 16:01
For comparison, this is what i get on 8700k 5Ghz + 3866mhz 16-16-16-36.
schizobeyondpills
Post by schizobeyondpills » 10 Jun 2020, 16:13
ptuga wrote: ↑
10 Jun 2020, 16:01
Tool didnt finish measuring latency, there's still pending measurements on L2-L2 H/Miss at the bottom, please test again with browser/discord etc all closed.
Anonymous768119
Post by Anonymous768119 » 10 Jun 2020, 16:14
Wow, that is huge difference. Obviously something is wrong with my rig but I don't have enough knowledge to solve it.
dervu
Post by dervu » 10 Jun 2020, 16:28
Ryzen 2600 @ 4.0, Corsair Vengenance RGB Pro 3200 CL16:
ptuga
Post by ptuga » 10 Jun 2020, 16:48
schizobeyondpills wrote: ↑
10 Jun 2020, 16:13
4000Mhz 15-15-15-35.
how do i make an image into a url
Test closes after l2-l2.
Anonymous768119
Post by Anonymous768119 » 10 Jun 2020, 17:39
So what I realized now, doesn't matter what frequency and timings I set, it's not affecting latency significantly and first steps are oscillating around 500us and then dropping to ~85.
Shyzo
Post by Shyzo » 10 Jun 2020, 17:55
Now that´s an interesting topic.
Would any of you guys mind to explain to me how I can install this program for windows?
I don´t really get the explanation on their page:
1000WATT
Post by 1000WATT » 10 Jun 2020, 18:42
ask schizobeyondpills, Brainlet. I think you are sitting in the same chair.
Brainlet
Post by Brainlet » 11 Jun 2020, 06:19
Shyzo wrote: ↑
10 Jun 2020, 17:55
Run CMD as admin, navigate to the folder and then type
mlc.exe
, optionally with with the avx instruction set
mlc.exe -z
Starting point for beginners: PC Optimization Hub
Shyzo
Post by Shyzo » 11 Jun 2020, 17:51
Thanks. I also did a run
Ryzen 3600, 3200Mhz Ram 16-18-18-36
Tomahawk B450 Max
