Does Mousetester/LatencyMon respond to emi?
Eonds
Re: Does Mousetester/LatencyMon respond to emi?
Post by Eonds » 23 Sep 2021, 19:12
lizardpeter wrote: ↑
23 Sep 2021, 00:08
So I ran some tests with three different values for MouseDataQueueSize. It does in fact seem like 0 sets it at the default value. The non-paged memory pool for both no registry value and 0 is 9872. With 16, however, it is only 1744.
Good to know.
Try these settings for your bios
Pcie Pll SSC - 2.0%
PCIe Spread Spectrum Clocking - Enabled
FIVR spread spectrum - Enabled
VRM spread spectrum - Enabled
RFI Spread Spectrum - 6%
bus clock spread spectrum (SB spread spectrum) - Enabled (-0.475%)
SRIS (separate reference independent spread) - Enabled
(enable all other forms of spread spectrum you can find as a yolo attempt)
This mostly fixed my issues
lizardpeter
Post by lizardpeter » 23 Sep 2021, 20:32
Eonds wrote: ↑
23 Sep 2021, 19:12
Pcie Pll SSC - 2.0%
Isn't spread spectrum being enabled worse than being disabled unless you have known EMI issues?
OP1 8K V2 | Field75 HE
Eonds
Post by Eonds » 23 Sep 2021, 21:02
23 Sep 2021, 20:32
Eonds wrote: ↑
23 Sep 2021, 19:12
Pcie Pll SSC - 2.0%
Every part in your pc emits emi, so not really. It can cause a slightly offset clock though
