High input lag and desync
- naporitan
Re: High input lag and desync i5 9600kf
bad hitreg
- dervu
Re: High input lag and desync (Problem solved.)
So what did you tell them and how did they answer?
- naporitan
I just wrote that the quality of electricity is bad, made my own independent measurements and asked to take action, and the indicator of the quality of electricity is the level of harmonic distortion across the spectrum of frequencies.
- naporitan
The problem is back after 5 days, waiting for the harmonic filter.
- 1008SKS-SHF-0010-2C5-15 (1).pdf
- (1.03 MiB) Downloaded 251 times
wadge
- naporitan
http://sikes-elec.com/filter/single-pha ... ic-filtersCan you explain how you proceed to install this filter ? or make a DIY ?
Where did you ordered yours ?
It is unlikely that you will be able to make your own hands such a filter.
- naporitan
I want to warn some people are misleading and do not want others to solve the problem...
- legend.png (19.73 KiB) Viewed 7256 times
Thatweirdinputlag
What did the power company do in the first place?
- naporitan
n0thing... I've just been duped... All hope for the harmonic filter.
wadge
Ok but how do you install it ?
