Checked, no differencePlznoinputlag wrote: β09 Dec 2021, 00:47check if you have reversed polarity in your outlets and main panelStimpy7314 wrote: β08 Dec 2021, 17:27I'm getting tired of this, i dont wanna play around 3:00 to have a smooth experience. that is to late. We need to figure something out. Anyone who has a tip just say it maybe it will work somehow?Plznoinputlag wrote: β06 Dec 2021, 02:06this is the answer we all want to know but we cant figure out. this bad input lag always came back and we dont know what causing it.Harts wrote: β05 Dec 2021, 15:28
I tested spartas steps to clear the whole system from electricity yesterday and I gotta say that it definitely made a difference while gaming. It lasted just for one day but it definitely made a difference. My question is what can I do in order to save my system from going back to the old status quo. I can't clear my system like that everyday...
Pc becomes faster/smoother during night time. During day time its slow/sluggish
Stimpy7314
Re: Pc becomes faster/smoother during night time. During day time its slow/sluggish
delve
nyxo100
electrical issue 100% or variation in voltage i have the two things
Stimpy7314
Stimpy7314
Lol
My pc was plugged into a non-grounded outlet. Its plugged in a grounded outlet now. Its getting beter now but not 100% fixed.
BFC
Hi dude.Did you find any fix?Stimpy7314 wrote: β29 Nov 2021, 12:33Will enabling sb spread spectrum reduce it? Because thats the only spread spectrum i have on my b450m steel legend mb.
Also will it decrease performance? Because the bclk freq will dip etc?
Headglitch123
Hi, stimpy here, But with a different accountBFC wrote: β13 Mar 2022, 05:45Hi dude.Did you find any fix?Stimpy7314 wrote: β29 Nov 2021, 12:33Will enabling sb spread spectrum reduce it? Because thats the only spread spectrum i have on my b450m steel legend mb.
Kinda βfixedβ it, what i did was restore bios options to default, and update bios to its fully. I only enabled xmp and sb clock spread spectrum, nothing else. Feels better also during day time
Spread spectrum options may be different, depends on manufacturer u have. For me asrock has only sb clock spread spectrum.
meljano
Can anyone help me find this spread spectrum setting in bios, cus i cant find it on my ASUS H110M-R motherboard?
Im desperate to try anything csgo hitreg and mouse movement seem to be completely desynchronized
Headglitch123
Either update bios or use scewin to change hidden bios settings.
Changing those setting would do nothing to csgo btw, csgo has lag compensation, causing desync etc. Anyway i could be wrong tho
meljano
Its updated to last possible version i have on asus site, any tuts on how to do that in scewin?Headglitch123 wrote: β14 Mar 2022, 12:12Either update bios or use scewin to change hidden bios settings.
