I FIGURED IT OUT! (After 2 years of trial and error)
Plznoinputlag
Re: I FIGURED IT OUT! (After 2 years of trial and error)
Post by Plznoinputlag » 17 Feb 2022, 11:35
FearDRAG wrote:
01 Jan 2022, 15:42
Hello,
It's almost been 3 days and I would like to report that the game is consistent as I had mentioned in the OP (Tested it not just in DM's but Unranked and even a Ranked games).
@akylen: Here, so basically I've disabled power limit control in the TPL menu, and changed the values of PL1 and PL2. Originally they were PL1- 45W and PL2- 107W, so I ended up changing them both to 45W and clamped them such that they don't exceed them. Here is the attached pictureTPL.png.
Furthermore, since my laptop had Turbo boost enabled by default, I went into the FIVR menu and changed the Turbo Ratio Limits, all of them to 41, such that they give me a max of 4.1GHz on all cores without thermal throttling. Pic attached here:FIVR.png
@MegaMelmek It's all good mate, I can understand it gets very frustrating, been there myself lol. For me right now, its almost 3 days and it's still the way I had described in the OP, hope it stays the same way, fingers crossed.
@Thatweirdinputlag I guess you could do it that way, but for me the MoBo and BIOS is pretty tight, so I couldn't really do it that way.
@Wayzer Yeah bro, I'm aware of the massive peekers advantage issue that they had a year ago and they supposedly had fixed it but there was no improvement I could see through their patch. I do not think it is a ping (usually get 30-40ms) issue, could be possibly a game engine one??
@Unreazz I did it through Throttlestop 9.4
@MegaMelmek Hey again! Honestly I feel like components or the CPU in this context is taking way more power than it needs to and then doesn't know what to do with the excess, kinda like eating a crap ton of food and then not being able to swallow it only to end up choking.
@akylen As I mentioned in the OP, I live in the same building as one of my highly ranked (immortal) friends' (who also plays on a laptop) which gets the same electricity from the same transformer for the apartment complex. I had tried my laptop in various towns away ranging from 5 to 50km's and still saw no difference. Even tried many different ISP's (cable, dsl and now fiber). If it were an electricity problem, probably then I could safely assume the entire state should face it, because the supply is from one same company. If I were to make a guess, I'd say its something related to the way electricity interacts with the components more specifically power draw by each of them whether it's in excess or the opposite.
@woodyfly I couldn't really change it through the BIOS, there's Intel's Extreme Tuning Utility and Throttlestop that I'm aware of that can do so as of now.
@MontyTheAverage 3 days in, don't see it worsen in any way as of now. Hopeful that I never encounter this demon ever again, fingers crossed.
tnx for the good info bro god bless you !
gunguro
Post by gunguro » 09 May 2022, 13:03
MegaMelmek wrote:
30 Dec 2021, 23:11
Have to say sorry man i did set my CPU on 65W (ryzen 5600x) and put some random Amps and its way smoother in game now not too much input lag. I am curios now for how long it will work. So far 4 games in row was not that bad.
Hello. Can you tell me how you changed the settings of the ryzen 5600?
gunguro
Post by gunguro » 09 May 2022, 13:55
Plznoinputlag wrote:
17 Feb 2022, 11:35
FearDRAG wrote:
01 Jan 2022, 15:42
Hello,
Hello. Can you tell me how to apply your settings to ryzen 5600? Help plz!
