Nah more or less nothing has changed since I last moved. I'm still actively looking for a fix/solution since I will have to get a permanent residence soon (i'm currently renting) and I don't want to have to deal with this all over again.Thatweirdinputlag wrote: β11 May 2022, 16:25Since you actually haven't found a fix, I'm assuming the input lag came back? even on an entire new setup and apartment? If that's the case then it would be nice of you to update your thread regarding this, since the last thing you mention there is that everything is working perfectly fine.NJb wrote: β10 May 2022, 17:48Your story sounds awfully similar to mine. Read this: viewtopic.php?f=24&t=9113
You're literally the first one I've seen who realized the problem also comes from the devices that you plug in.
Sadly, no fix yet
Some New Interesting Findings on My Long Battle With Input Lag and Desync Issues
NJb
Re: Some New Interesting Findings on My Long Battle With Input Lag and Desync Issues
Ogmax
Anyone found any fix or some kind of solution for this ???
- Cyanide_
Anyone has any idea how to check your new place for these issues? Maybe make some measurements, or bring a gaming laptop to play few matches or idk what else. Renting rn too, don't wanna get my own house/apartment and realize it's "bad" for gaming as well. Same applies to "old renting place" vs "new renting place".NJb wrote: β14 May 2022, 12:07Nah more or less nothing has changed since I last moved. I'm still actively looking for a fix/solution since I will have to get a permanent residence soon (i'm currently renting) and I don't want to have to deal with this all over again.Thatweirdinputlag wrote: β11 May 2022, 16:25Since you actually haven't found a fix, I'm assuming the input lag came back? even on an entire new setup and apartment? If that's the case then it would be nice of you to update your thread regarding this, since the last thing you mention there is that everything is working perfectly fine.NJb wrote: β10 May 2022, 17:48Your story sounds awfully similar to mine. Read this: viewtopic.php?f=24&t=9113
Sadly, no fix yet
