My experience with all sorts of Problems regularly mentioned here.
Locked
ZINZIRIO
Re: My experience with all sorts of Problems regularly mentioned here.
Post by ZINZIRIO » 22 Apr 2025, 20:35
dervu wrote:
21 Apr 2025, 04:59
ZINZIRIO wrote:
21 Apr 2025, 00:50
ZINZIRIO wrote:
20 Apr 2025, 10:12
How can I know from my side if I have to connect with TN-S, meaning a different ground for the neutral than for the safety ground, or a TN-CS that shares the same, neutral and safety ground on the same rod? Today I made the connection from TT to TN-S and the mouse becomes very fluid and all the desynchronization problems disappear... But my question is which system to use, assuming that with either of the two the problem never returns.
Unfortunately the problem returned as expected... I am completely unsure if the problem is with respect to ground or has to do with the quality of the energy I am receiving through the neutral... Installing solar panels is not an option so I guess I will never solve it, it is quite frustrating... I have tried absolutely everything and the problem always returns... The only thing that has made a noticeable difference for me is connecting the neutral to ground but for some reason everything is filled with that static again.
I'm seriously considering trying an isolation transformer, but no one has solved the problem with one, so my hopes are very low, and once I buy it, I can't return it.
There is always Hail Mary way and try out:
https://www.youtube.com/watch?v=YHhGt-z62wU&t=1s
Online UPS + Some good filter + med isolation transformer, but yes it might be hard to return.
How was the connection with the copper cable, was there any improvement? I still have the problem but when I enter a game the mouse becomes increasingly heavy until I return to the desktop, I have to wait about 15-20 minutes and the fluidity of the mouse returns, in my case the problem has a lot to do with the consumption of my PC I have a 13700K 4070TI and a Corsair RM850 year 2021. I tried a new similar source, Corsair 850X Shift of 850W and the problem returned after hours of using it...
Do you recommend I buy a 1200W power supply? Or is my problem different from yours?
Post by Slender » 22 Apr 2025, 22:58
dervu wrote:
21 Apr 2025, 04:59
ZINZIRIO wrote:
21 Apr 2025, 00:50
ZINZIRIO wrote:
20 Apr 2025, 10:12
do you have that combination? why u advice that?
Vocaleyes
Post by Vocaleyes » 23 Apr 2025, 00:41
ChristophSmaul1337 wrote:
20 Apr 2025, 11:26
ZINZIRIO wrote:
20 Apr 2025, 10:12
You might be able to guess from looking at the breaker panel: Think about your panel for a second and go back in time to before you made any changes or modifications. You said you get 2 wires delivered to your main electrical panel from the utility. First question to ask would be if you live in a house or if it's an apartment building. If it's a house, make sure the panel you're looking at is actually the main panel for the whole house. If it is, you should look at the color of the wires coming in. One of them is either black, grey or brown. That would be the live wire. The other one is colored either blue or yellow-green striped with blue mixed in. If the second wire is blue, it's a TT system, and if it's yellow-green striped with blue mixed in it's a TN-C-S system. However, color coding isn't always done right and can be wrong. So, for you to confirm it, think about the connection between the second wire and the grounding wire. Was there a connection there in the first place, did you take it out or was it not there at all before? If it wasn't there, it's likely TT, if it was it's likely TN-C-S.
More hurdles for you: Is your main panel actually the first thing the wire from the utility encounters inside your house? There might be a box we call "Hausanschlusskasten" (=house connection box). It contains the main fuses for the whole house. It looks something like this: https://upload.wikimedia.org/wikipedia/ ... A_500V.jpg This contains the 3 main 63A fuses (I have a 3-phase installation). If the electrical installation was done right and you're on TN-C-S, the PEN wire should be split up into PE and N inside this box. However, after this box, there should then be 3 wires going to your main breaker panel, 1 phase, 1 neutral and 1 PE/ground. Is your incoming wire a PEN and was it split up inside this fuse box? I for example can't tell, because it's sealed and only licensed electricians are allowed to open it up (it's before the electricity meter). Maybe your installation is supposed to be TN-C-S and somebody forgot to run the PE wire from the main fuse box to the breaker panel. Maybe you're getting a blue neutral wire, which would be a regular TT, but you're actually supposed to get a PEN. Or maybe it's just a regular TT and it's supposed to be like that.´If you're in an apartment building, it's even more convoluted as your breaker box definitely isn't the first thing the wires encounter within the building...
In short, the safest and most reliable way of figuring out what your grounding system is supposed to be is to call the system operator and ask. If they can't answer, call a licensed electrician. If he won't tell you, either call another one or have one come to your home and check the installation.
ZINZIRIO wrote:
20 Apr 2025, 10:12
That's a question only the utility will be able to answer. You can make a good educated guess, but you can never be certain. The grounding system is governed by the utility, more specifically by something we refer to as the "Netzbetreiber" (=electrical system operator), the company that ownes the physical infrastructure. This doesn't necessarily have to be the company you pay, as companies can resell foreign infrastructure, similar to internet providers. Try calling your power company first. They might or might not give you the information. If they don't or can't, call the system operator. Your electricity meter might have a sticker on it with a phone number to call in case of a fault, and that number usually belongs to the system operator. They will definitely have the information on your grounding system, however they might not give it to you. In that case, call a licensed electrician. Any electrician worth their pay should have access to the database of the grounding system used at your address, and they should also be able to tell immediately from looking at the panel if everything was done right.
ZINZIRIO wrote:
20 Apr 2025, 10:12
Could indicate that your grounding is really bad or non-existent. You mentioned in a previous post that you found a connection from your earthing system to the water pipes. If your water company ever changed out a bit of pipe, they very likely inserted a plastic piece. This nullifies the grounding in your house. If this is what was relied on to create the safety ground for the RCD to trip, I would highly suggest getting an electrician anyways, because your installation might very well not be safe anymore.
Here's my honest advice: Call your utility, system operator or an electrician and get info on which grounding system is used at your address right now. After making that call and having it confirmed, post the result here. If it's confirmed that you should be on TT, get an electrician to check out your installation and have him take a measurement of ground resistance and RCD trigger times.
Weird mouse input and computer problems aside, a TT system without a proper ground rod and therefore too high of ground resistance is a huge safety hazard and you should get it fixed ASAP.
EDIT: Apart from the safety concerns, I still stand by the opinion that the safety grounding doesn't influence the computer when under normal conditions. There are countries whose national electric code doesn't even require a 3-prong outlet and devices are never grounded. One such example is Egypt. Nevertheless, people from Egypt can play video games just fine and not every Egyptian ever in the existance of the country suffered from weird mouse problems or desync. Safety ground, apart from the obvious function as a safety feature, doesn't have any function inside the computer. It's there for one thing only, to protect the user in case of a ground fault.
The fact that the safety ground is bonded to the DC ground inside the PSU however might lead to weirdness, but why that would happen and under which circumstances I'm nowhere near qualified enough to make sense of. What I've seen so far, noise, interference or whatever else might be on the safety ground which isn't supposed to be there, can influence the way a computer functions, possibly by changing the path the DC return current takes back to the PSU. It's the best guess I have so far.
When you say you noticed the mouse cursor being smoother on the desktop after installing the 1200w PSU, could you perhaps go into more detail comparing the feeling of this smoothness please? Like is it more visible smoothness or feeling etc. thank you.
dervu
Post by dervu » 23 Apr 2025, 08:48
Slender wrote:
22 Apr 2025, 22:58
dervu wrote:
21 Apr 2025, 04:59
ZINZIRIO wrote:
21 Apr 2025, 00:50
ZINZIRIO wrote:
20 Apr 2025, 10:12
Yes. I tried it out and it fixed issue completely (with even better EMI filter than this guy), but I don't run it now as it's annoying with loud UPS and having to disconnect all wiring behind the socket I connect it to (so also disconnecting another room and having to drag another wire there to power devices in that room). Not worth for me to buy another expensive UPS now until I find out if something else I am waiting for will fix it or not. Only then I would go back to it.
I tried it out multiple times, couple days each time, then come back to connection straight to socket and then back to this setup again. It always worked.
Only thing I couldn't explain was CPU-Z timers being completely synced (all three) while having it off grid (so on battery only), while connected to grid it wasn't. It wasn't translating to any symptoms though.
It's simply nuke from orbit approach, but it's expensive. You have to also look out to not have unfiltered fields coming near output of those devices so none of interference would be able to jump anywhere.
At such price point you might as well buy power station and disconnect it from grid, but it will never be continuous powered hardware, so it's hard to tell if it even works for longer time.
The thing is noone can guarantee it will work in every case as you would have to measure what frequency affects your hardware and target that. Some will get lucky with some approaches like that, some might not. I don't even know if it filters everything it could. By theory it should filter a lot, but even online UPS doesn't have complete separation, as there is still ground wire. I tried with 3 to 2 prong adapter on UPS, that didn't make any difference in my case, it was still fixed.
ZINZIRIO
Post by ZINZIRIO » 23 Apr 2025, 09:04
dervu wrote:
23 Apr 2025, 08:48
Slender wrote:
22 Apr 2025, 22:58
dervu wrote:
21 Apr 2025, 04:59
ZINZIRIO wrote:
21 Apr 2025, 00:50
Are you using the same isolation transformer as the video? Are you also using cable from GPU to PSU?
dervu
Post by dervu » 23 Apr 2025, 10:01
ZINZIRIO wrote:
23 Apr 2025, 09:04
dervu wrote:
23 Apr 2025, 08:48
Slender wrote:
22 Apr 2025, 22:58
dervu wrote:
21 Apr 2025, 04:59
Not exact the same, but with similiar technical details: IS1800HGDV. I was not using cable from GPU to PSU at the time.
Hyote
Post by Hyote » 23 Apr 2025, 13:00
I don't want to butt into a conversation where I have zero knowledge but I have to add my viewpoint, because it's definitely as much of a software issue as it is a hardware one. I have builds of almost version of Windows and just by the install screen you can tell everything newer than 7 is going to be gargbage. Almost as if input lag is implemented into the core of the OS. I still have some minimal desync and I'm going to share a video in a separate post but for me most of the lag only ever came from Windows. So if anyone claims to get perfect mouse feel by doing tweaks or making physical changes can't be 100% honest.
ZINZIRIO
Post by ZINZIRIO » 23 Apr 2025, 13:22
dervu wrote:
23 Apr 2025, 10:01
ZINZIRIO wrote:
23 Apr 2025, 09:04
dervu wrote:
23 Apr 2025, 08:48
Slender wrote:
22 Apr 2025, 22:58
Unfortunately, I don't have access to these types of transformers in my country, and buying them abroad is very expensive. I could buy one, but it's not medical grade; it's traditional, and I doubt it would make a noticeable difference. Was your problem related to the PC's power consumption, or was it even in the desktop? My problem is when the PC's power consumption exceeds 50% or more.
dervu
Post by dervu » 23 Apr 2025, 14:07
ZINZIRIO wrote:
23 Apr 2025, 13:22
dervu wrote:
23 Apr 2025, 10:01
ZINZIRIO wrote:
23 Apr 2025, 09:04
dervu wrote:
23 Apr 2025, 08:48
In my case it's related to power consumption. The more power draw usually it was worse. Even leaving PC on idle for some time and then coming back it feels different. Issue can be felt even on desktop.
Vocaleyes
Post by Vocaleyes » 23 Apr 2025, 18:13
Hyote wrote:
23 Apr 2025, 13:00
"So if anyone claims to get perfect mouse feel by doing tweaks or making physical changes can't be 100% honest."
You assuming that everyone's issue is identical to yours therefore "they must be lying", is extremely narrow sighted and unhelpful. Especially in contrast to the lengthy testing and technical explanations the OP has provided. Great job! :roll:
Locked
