[EMI] 1500mV When computer is running!!!
Re: [EMI] 1500mV When computer is running!!!
Post by Slender » 14 Apr 2025, 20:01
one person sent me a filter on x2 capacitors, and I was able to reduce the amount of mv from 1700-1850 to 500mv, with the PC on, but it did not affect anything at all.
spkii
Post by spkii » 15 May 2025, 10:15
I tried with EMI metter, my computer has 1700 mV when turned on, if not turned on. 90-100mV values in all sockets of house... what u recommend guys?
delve
Post by delve » 15 May 2025, 22:10
spkii wrote: ↑
15 May 2025, 10:15
can you measure desktop vs. in game with the meter?
spkii
Post by spkii » 16 May 2025, 02:33
Fixed!!!!!!!!!!!!!!!!!!, no mor mV with this setup:
https://ibb.co/SwkL1kxf
Video:
https://files.fm/f/5hj8f7ytj5
Now its like only 45mV with this setup (one GreenWave filter too connected to the Anti EMI Power Strip.... Will see if this fix totally this worldwide problem or is not related to this EMI...
dervu
Post by dervu » 16 May 2025, 03:57
This kind of measurement does not mean anything. It's too generic.
Greenwave is a joke.
spkii
Post by spkii » 16 May 2025, 05:37
dervu wrote: ↑
16 May 2025, 03:57
Why not??? explain, i changed from 1700mV on line to 50mV...
Post by Slender » 17 May 2025, 11:25
spkii wrote: ↑
16 May 2025, 05:37
dervu wrote: ↑
16 May 2025, 03:57
the frequencies that your tester sees have nothing to do with our problem. The only place where you might be able to hear a difference is sound and image.
spkii
Post by spkii » 17 May 2025, 16:15
Slender wrote: ↑
17 May 2025, 11:25
spkii wrote: ↑
16 May 2025, 05:37
dervu wrote: ↑
16 May 2025, 03:57
As the thread says, this EMI is causing desync and mouse lagg on several users here. In my case i tried 2 different houses, different computers, software, and 2 different ISP, tried with Wifi and Ethernet and 5G on Mobile too. Tried with a EcoFlow Delta Pro offgrid too...
The only reason i think it can cause is this EMI higher than normal (25mV or less).
spkii
Post by spkii » 28 May 2025, 07:22
1 week trying 1 filter GreenWave with this: https://www.amazon.es/dp/B09S64J8Y7?ref ... asin_title. Computer, Screen and router connected to this and GreenWave filter too is in.
EMI Metter now says 50-60mV. And its the first time i can see literally something close to 100% no input lag feeling!. Without the GreenWave filter i had 150-200mV, Now its better in all ways but filter didnt solved at 100%, its a way way better now... I probably buy some filters more to test try low mV under 25.
The EMI filter GreenWave didnt act instantly, it took like 3 to 5 days to react to electricity situation and started working good.
Ali
Post by Ali » 09 Nov 2026, 08:24
All of your EMI levels are child's play, and you all need a little more knowledge about EMI.
My house has over 2,000 mV of noise during the daytime because there is a car service centre near my house. Their centre and our house share the same grid. Whenever they turn on their machines, the differential-mode noise in my house spikes from 700 mV to over 2,000 mV.
I've tried a bunch of EMI filters. They reduced the EMI slightly, but they didn't improve my PC's response. The reason is that generic EMI filters add high impedance, and they don't have ground-wire EMI filtering. EMI also travels through the ground wire. So, a proper EMI filter should filter EMI without adding high impedance and should also reduce EMI on the ground wire.
As far as I know, only OnFilter CleanSweep EMI filters can reduce 1,800 mV of EMI noise to less than 50 mV. However, we need to use one for the PC and another OnFilter for the monitor.
As people have mentioned in these forums, PCs and monitors inject their own EMI into the power line. If you use one OnFilter and plug a power strip into it, then connect your PC and monitor to the same power strip, your PC and monitor will pollute each other by injecting their own EMI.
I have a Corsair RM850x ATX 3.1 PSU, which injects around 600–700 mV of EMI noise into the power line. My AOC CS24A 600 Hz monitor injects around 200 mV of EMI noise.
Even though OnFilter reduces incoming AC mains EMI from 1,800 mV to 50 mV, the PC and monitor can still pollute each other with their own injected EMI.
To prevent this issue, we should buy a 10-amp-rated CleanSweep EMI filter for the PC and a 3-amp-rated OnFilter for the monitor.
Here's what we should do: Plug a power strip into a wall outlet. Then plug the 10-amp and 3-amp OnFilter units into the power strip. After that, plug only your PC into the 10-amp OnFilter and your monitor into the 3-amp OnFilter. By doing this, you can filter AC mains EMI as well as the EMI injected by your PC and monitor.
I'm currently using a setup close to this, and I've fixed 75% of the issue. I still need to fix the remaining 25% because my country's electrical grid has high impedance. The only way to fix this issue is to use an ultra-low-impedance LiFePO4 battery and a low-frequency pure sine-wave inverter. However, I'll still use my OnFilter units because inverters also generate high levels of EMI noise.
I use AI to correct my grammar mistakes because my English isn't very good. Don't waste your money on snake-oil audio power conditioners. The majority of them are very expensive, and they can't filter ground-wire EMI or filter EMI noise without adding high impedance.
Today, my house has less than 1,100 mV of EMI noise because the car service centre near my house is closed, so all of its EMI-generating machines are turned off. I know some people tried onfilters but using only one onfilter is not enough because PC and monitor inject their own emi and polute each other even onfilter company saying we should only plug one sensitive equipment on their filter so we need to use two separate filter for PC and monitor
My onfilter
My onfilter
This is after using onfilter
This is without using onfilter
