0.0.0.0 on your ntp server means you are not retrieving the time from ntp server. That made it clear for me. Router - set timezone. Pc - set manually your time+1 minute. ThanksGhosty_Ind wrote: ↑20 Aug 2025, 16:06I think router itself retrieves it from NTP and sets it's own time as per NTP retrieval. All I did was select/verify the correct time zone when I was setting it up for the 1st time.. That means it's without the +1 minute.. The original NTP time..kriegsnake wrote: ↑20 Aug 2025, 16:05So from the router point of view you’ve set it manually to your timezone without adding +1 minute. Correct me if I’m wrong.Ghosty_Ind wrote: ↑20 Aug 2025, 16:01Router NTP.pngMy bad, it seems like it can get the timing from NTP or windows... Here are the settings :kriegsnake wrote: ↑20 Aug 2025, 15:54
Haven’t tested yet , but I have a question. You told to reboot router too. Can you jump into your router and tell me if it syncs the time with your pc,ntp or manually?
No FPS gaming possible
- kriegsnake
Re: No FPS gaming possible
Ghosty_Ind
Glad to help out fellow problem solvers !!kriegsnake wrote: ↑20 Aug 2025, 16:090.0.0.0 on your ntp server means you are not retrieving the time from ntp server. That made it clear for me. Router - set timezone. Pc - set manually your time+1 minute. ThanksGhosty_Ind wrote: ↑20 Aug 2025, 16:06I think router itself retrieves it from NTP and sets it's own time as per NTP retrieval. All I did was select/verify the correct time zone when I was setting it up for the 1st time.. That means it's without the +1 minute.. The original NTP time..kriegsnake wrote: ↑20 Aug 2025, 16:05So from the router point of view you’ve set it manually to your timezone without adding +1 minute. Correct me if I’m wrong.Ghosty_Ind wrote: ↑20 Aug 2025, 16:01Router NTP.png
LaggyTyp
I tried it, but unfortunately, it doesn't change anything for me. That round just now felt awful.
I'm reinstalling Windows this week. I'll report back.
Thank you for your help anyway! I know you mean well, and I kiss your heart for that!
Best regards to India my friend!
PS: Give me a few days to remove all snake oil tweaks (fresh Windows without tweaks)
Ghosty_Ind
I feel sad to hear this news, but I got few good feedbacks as to how this fix helped them... Maybe reset your BIOS to default, just enable XMP or DOCP, reinstall fresh windows and also as kreig mentioned above, do check your Router settings that it is in sync with your timezone.. That's all I can offer.. I was waiting for your response specially... But I hope that after that fresh reinstall (since I saw your previous posts of deleting the dynamictick and platformclock, I suspect that could be the cause where this fix did not work for you).LaggyTyp wrote: ↑20 Aug 2025, 16:23I tried it, but unfortunately, it doesn't change anything for me. That round just now felt awful.
Reinstate the original windows and then try.. I think it will work for you too...
- themagic
Sad...LaggyTyp wrote: ↑20 Aug 2025, 16:23I tried it, but unfortunately, it doesn't change anything for me. That round just now felt awful.
For me its like too not full Fix still and far from what I already saw and know how the Game can work even much better...
But this Tweak from this Dude and the Steps clearly make some change that i could clearly feel again and see and the difference and after Reboot but it like degrade very quick here and i start feel problems again...bad hitreg, like desync, enemy start to become unkillable and so on...
I even get not long ago a Windows stopcode Bsod lol...which i never had for long time on this one PC...
Anyway...
It all still needs more Test and I right now myself try to figure out what the Hell is going on and understand and how to make it all work somehow Stable and so that it all last for long without degrading...and dont only for 2-3 Match haha...
Soon we will know...maybe
But big thanks to this Dude and this Method Steps that everyone can try by himself and repeat as much he want and maybe will too see the changes...It all help me some more to understand...
- kriegsnake
Same here. It didn't do anything even slightly better in my case.
Ghosty_Ind
I have 1 more PC in my other hometown. I will be going to spend a week off vacation there, and will test the same thing myself...themagic wrote: ↑20 Aug 2025, 16:56Sad...LaggyTyp wrote: ↑20 Aug 2025, 16:23I tried it, but unfortunately, it doesn't change anything for me. That round just now felt awful.
Anyway...
Soon we will know...maybe![]()
For me, the fix for few seconds do not work (meaning I felt desynced in few of the match rounds), maybe due to the minute long delay which was added, maybe we need to make it shorter, so that it keeps more in sync, will fine tune on that but in a week's time.. The fix requires more testing yes, but for me for 2 Premier CS2 matches, Damn was I able to move and shoot.. And the changes stayed for all my 3 sessions without changing anything else.. Will test more and keep you all posted..
Ghosty_Ind
Do you have any other optimisations done as part of other fixes ?kriegsnake wrote: ↑20 Aug 2025, 17:03Same here. It didn't do anything even slightly better in my case.
LaggyTyp
Ghosty_Ind
Similar shit happened with me for CS2 (Enemies so fast that it was difficult to track them), sloppy mouse movement, the gun spray is inconsistent and didn't understand where the spray went - always to the sky.. Same for Valorant and BF1.. Enemies used to kill me before I even saw them while I was peeking.
