Please try to restore all of them to default before testing this fix.dermodemon wrote: ↑21 Aug 2025, 03:25i tried @Ghosty_Ind fix. Didn't saw any difference.all bcdedit platformclock and dynamicticks are deleted
FTTH 1000/1000
No FPS gaming possible
Ghosty_Ind
Re: No FPS gaming possible
Ghosty_Ind
I will share a Screenshot of my time settings after 5-6 hours, just so you all have that same options..Ghosty_Ind wrote: ↑21 Aug 2025, 03:44That should be your culprit then.. The windows shit is toggling it on somehow but don’t know why.. Mine is in manual mode even after multiple restarts/shutdowns and startupsMontyTheAverage wrote: ↑21 Aug 2025, 02:53I tried it also. thought it helped for 5 mins but don't think so. Same issues. Got worse again after few mins.Ghosty_Ind wrote: ↑21 Aug 2025, 02:03@kriegsnake and @LaggyTyp - which CPU and GPU are you guys using ???
But i saw the "set time automatically" option gets toggled on after restart. Was it same for it? Follow yours. But not sure If Im doing something wrong?
MontyTheAverage
but the time I set like 1 minute more than the phone stayed though even though set time auto thing was toggled one after restart.Ghosty_Ind wrote: ↑21 Aug 2025, 03:44That should be your culprit then.. The windows shit is toggling it on somehow but don’t know why.. Mine is in manual mode even after multiple restarts/shutdowns and startupsMontyTheAverage wrote: ↑21 Aug 2025, 02:53I tried it also. thought it helped for 5 mins but don't think so. Same issues. Got worse again after few mins.Ghosty_Ind wrote: ↑21 Aug 2025, 02:03@kriegsnake and @LaggyTyp - which CPU and GPU are you guys using ???
Ghosty_Ind
Can you disable that auto again and try to play once ? Also, if it gets worse after 5 mins, keep on playing for 10 mins or so, and if it feels constantly the same worse laggy feeling, check in the Date Time settings if it got toggled to automatic again somehow ?MontyTheAverage wrote: ↑21 Aug 2025, 04:23but the time I set like 1 minute more than the phone stayed though even though set time auto thing was toggled one after restart.Ghosty_Ind wrote: ↑21 Aug 2025, 03:44That should be your culprit then.. The windows shit is toggling it on somehow but don’t know why.. Mine is in manual mode even after multiple restarts/shutdowns and startupsMontyTheAverage wrote: ↑21 Aug 2025, 02:53I tried it also. thought it helped for 5 mins but don't think so. Same issues. Got worse again after few mins.Ghosty_Ind wrote: ↑21 Aug 2025, 02:03@kriegsnake and @LaggyTyp - which CPU and GPU are you guys using ???
LaggyTyp
I just played a round.
- 14 kills in the first few minutes
- Then nothing worked anymore (my shots weren't connecting)
- Then suddenly it worked again
- Then it didn't work again (my shots weren't connecting)
WHAT THE FUCK?
It's making me sick.
WHAT THE FUCK?
Ghosty_Ind
That’s somewhat true with what I played in Cs2. But in terms of smoothness, it was like day and night for me…
I think, we will have to see maybe the Bios time also, and maybe, maybe the router Time also… I will work on it don’t worry.. I think we would be onto something here…
LaggyTyp
I just noticed that my BIOS clock was completely messed up. I've now set the current time +1 minute.
Windows clock is exactly +1 minute (set with an atomic clock)
Ghosty_Ind
LaggyTyp
Unfortunately not. I think it's beyond my control (ISP).
What makes it very difficult is that sometimes things go very well. Then, if you happen to change something, you think that's the problem.
It's a disease.
It's a disease.
Ghosty_Ind
I know this feeling, trust me I do.. But the clock change shit, has given me such a feeling that I did not have before… Hence I told you it’s so silly but somehow is consistent for me..
Btw, which Processor and GPU are u using can I know ? Just to maybe think about the platform.. Also, did you restore the dynamictick and platformclock settings.. I suggest you do that too before losing hope.
