BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
Amoxap1ne
I manage to overclock my XL2430T v2 to 210Hz (6 bpc) and 158 (8 bpc), I use 210hz for CS:GO and 158hz for PUBG. I did it due to the fact that my unit have "Dynamic Black eQualizer" which is annoying. And above 146hz ( I think) it disable the dynamic Black eQ for the traditional one. For create the custom resolution I used CRU.exe (209.997hz) and on top of that I created a the same resolution at 210hz in my Nvidia control panel, if would't do so 210hz would look with YCbCr422 colors which look really bad. My customs resolutions are 1920x1080 (obviously), 1440x1080, 1280x960 and 1024x768. Another thing is that when I use 158hz i get horizontal lines which doesn't go away unless I spam my S-Switch. Otherwhise the OC worked well!
n1ghtik
Hi everyone, how can I put the black bars in cs go on the amd graphics card (rx 580 4gb). I oc my screen resolution up to 200Hz, but I can not play cs go with black bars. 1152x864 200hz
when I try to enable gpu scaling in the video card settings, my oc resolution just doesn't work.
benjicod
Is there a option to overclock display without 2nd monitor?
th3_baboon
Hello , I was wondering if someone could help me fix this problem. When I set my monitor to 200hz and get the oor error(step 8) I go to the soft MCCS program and it crashes, I have no idea why. can someone pls help thanksss
weirdo
Hello
i made 210hz (full hd, displayport) on benq xl2411p with Sapphire Radeon RX 580 PULSE 4GB GDDR5 and i have some questions/issue.
1. If i add custom resolution in cru bigger then 210 hz i don`t see nothing on windows settings, do you have maybe idea why?
2. I don`t see difference between frame rate 144 and 210 on https://www.testufo.com/framerates-versus
So, it is a problem with this benchmark or with my display? Another tests on www.testufo.com pass correctly.
3. When i turn off and turn on my pc i have still out of range error. I have OORBuster and OORFixer in autostart, hotkey alt + home works but not in this case (restart computer). Do you know how to fix it?
CSGO and Valorant works on 210 hz.
- test2.png (217.5 KiB) Viewed 10859 times
- test1.png (562.74 KiB) Viewed 10859 times
- 210hz_works.PNG (30.78 KiB) Viewed 10859 times
destor1ze
Hey hleV, im trying to use your app OORbuster.exe but i cant figure out how to get launch parameters working. I just want to add more "OOR delay" (8000 instead of default 2000), so this is how my target field looks like:
"C:\Users\xxxx\Desktop\oorbuster\OorBuster.exe" -8000
but the delay doesnt seem to work, am i doing something wrong?
- hleV
As per README.md, parameters should look like this:destor1ze wrote: ↑15 Jun 2020, 10:26
Code: Select all
2000 500 250 3000Code: Select all
"C:\Users\xxxx\Desktop\oorbuster\OorBuster.exe" 8000 500 250 3000BenQ XL2546K @ 240Hz (DyAC+) • ROCCAT Kone Pro Air @ 1000Hz • HyperX Alloy Origins • CORSAIR MM350 PRO Premium • HyperX Cloud Revolver • NVIDIA GeForce RTX 3070 @ 2130MHz/8000MHz • Intel Core i7-8700K @ 4.8GHz • G.SKILL RipjawsV 16GB (2x8GB) 3000MHz CL15
sosuyike
hleV which Xl2411Z settings did you end up using?
- hleV
The default ones that I set in OOR Buster: 2000 500 250 3000.
sosuyike
