What will a fine PC's latencymon result look like?
Re: What will a fine PC's latencymon result look like?
Just gotta make sure to get a low sleep delta, I forgot this previously.
- untitled.png (7.24 KiB) Viewed 6946 times
You've ran a program at idle for 30s, to showcase what exactly?
A random number whose value you don't understand so poor souls think you know something they don't?
LatencyMon is not a good tool to test/benchmark/evaluate ANY windows driver performance. It never was, it never will be.
ETW data & WPA (Windows Performance Analyzer) scripts such as xperf or it's alternative, easy-to-digest, front-ends (XTW) are the only proper way to benchmark windows drivers the official way.
Refer to the thread in my signature on what methodology I've employed for my testing of USB controllers & their different drivers for 8kHz mice.
evaluating xhci controller performance | audio latency discussion thread | "Why is LatencyMon not desirable to objectively measure DPC/ISR driver performance" | AM4 / AM5 system tuning considerations | latency-oriented HW considerations | “xhci hand-off” setting considerations | #1 tip for electricity-related topics | ESPORTS: Latency Perception, Temporal Ventriloquism & Horizon of Simultaneity | good lcd backlight strobing implementation list
I am aware that the program is not to be used for actual benchmarking and I'm not trying to flex on others by showing these numbers, it is a continuation of my previous answer where I wrongly stated that kernel timer latency will always be in the hundreds because of the timer resolution.kyube wrote: ↑20 Feb 2025, 17:59You've ran a program at idle for 30s, to showcase what exactly?
And to be honest regarding Windows optimization I really do know more than most people because I am not afraid to explore the depths of ideas and not just call it a day when something doesn't seem sensible. That being said I don't like actual bullshit either and want to learn whenever I can but the approach from actual tech guys denying everything because of how they know things are right, is just as bad. I watched a lot of people who were the cornerstones of the tweaking community become attached to the idea of how things should work and throw away everything they found and made everyone else chant the magic words placebo.
I am never going to understand the approach of "sensibility" when you can achieve a lot by sacrificing unnecessary things that people find too hardcore or risky because of how minimal the gains are in their imagination.
Also I ran the tool on idle that is true, but if I open basic programs and move my mouse as fast as I can there is not much difference. But again I just wanted to explain one thing and this was a good way to do so.
Hi, I registered on this forum to message you, but it won't let me DM you because my account is new.jc008titan wrote: ↑09 Sep 2023, 11:46I mostly used Calypto latency guide for the results(big impact), but I used a lot of different tweaks I learned in the past 5 years from varius sources(some of them were: EverythingTech, Fr33thy, World of PC).
I'll make a list of apps i used to optimize my pc(some may be placebo, but it works in the end*):
winaero tweaker(big impact), iobit uninstaller, ccleaner(first 3 uninstalled after use), quickcpu(run once when pc starts), cpu core parking, parkcontrol, process lasso(i think this is the best app out there), mem reduct, rtss, msi afterburner, islc, timer resolution(last 7 are running in the background at all times), morepowertool, DDU, moreclocktool(those last 3 for gpu tweaks), interrupt affinity policy tool(very important when balancing cpu usage on the cores(at affinities, select everything except core 0 on usb, gpu, network and sound)), msi util v2, autoruns(disable useless background tasks).
It takes me about an hour to do all the tweaks(got used to it after having to do it so often).
I can get most computers/laptops to run in under 2.5us average interrupt to process latency and under 1us average interrupt to dpc latency using the above apps.
I am willing to learn about more tweaks to get my pc to have an even lower interrupt latency.
Would you be willing to fix the Latency on my system if I paid you?
I am an older guy and not so techy.
