Page 4 of 6
Re: Input lag AB test
Posted: 18 Aug 2014, 23:06
by flood
got bored and tried this again.
just got 17/25 for 10ms
if you add up my three results (16,15,17) you get 48/75
that's a p-value of 0.01 !!!
anyway a situation where 10ms input lag for sure affects performance is in csgo, dust2, awping enemies running across mid double doors from t spawn. you need about a reaction time around 0.15 to 0.17s to kill them as they cross the gap. and for that, an additional 10ms of input lag can definitely lead to missed shots.
Posted: 05 Nov 2014, 19:45
by oblistar
First two tries just now,
50ms: 25/25
5ms: 18/25
This is a fantastic app. damn. I play a rhythm game called 'osu' and despise input lag with a burning passion. Placebo my azz. ty for this
Posted: 05 Nov 2014, 22:53
by flood
oblistar wrote:
5ms: 18/25
uwotm8
can u try at 10ms?
Posted: 11 Dec 2014, 03:10
by mokuh
50 ms : 25/25
8 ms : 25/25
4 ms : 14/25
So as I expected, I'm very sensitive to input lag until below 8 ms.
Posted: 27 Jan 2015, 10:26
by shish_KEbOB
Nifty little program, thanks!
My suggestion would be to add geometric shapes in the background to have some reference point.
I find that doing the same movement repeatedly loses effectiveness with repetition.
Your brain just gets used to it and you can't tell the difference anymore.
I find myself combining all sorts of movements: circles, eights, squares, crosses, Xs, triangles, moving from side to side of the splitting bar, etc...
Some shapes so that one can trace the perimeter in the fastest/most accurate way would make the test more effective in my opinion.
Posted: 15 Feb 2015, 09:57
by Aibo999
50 ms : 25/25
25 ms : 25/25
4 ms : 18/25
Samsung SyncMaster 2032BW 70Hz
Posted: 20 Feb 2015, 00:32
by lexlazootin
I really want to try this but my version of the program is v-syncing on windows 8. is there something I should be doing?
I don't think getting 18/25 is enough to determine you can tell a difference. you could easily just click one side and every (Something) of a person would get it too easily. (If someone could tell me how to do the math of figuring out how many people would get ATLEAST 18/25 please tell me)
EDIT: NM I can force it off with amd drivers... silly me.
Posted: 07 Apr 2015, 18:23
by MaximilianKohler
lex how did you force it off with AMD?. In CCC I put it to "always off", but the FPS stays the same as my hz.
Posted: 07 Apr 2015, 20:02
by Sparky
MaximilianKohler wrote:lex how did you force it off with AMD?. In CCC I put it to "always off", but the FPS stays the same as my hz.
I had to use radeonpro to force it off.
Posted: 08 Apr 2015, 05:32
by lexlazootin
yea idk, it's kinda fooked. i had to just keep changing setttings till it worked... it's pretty random, i would edit the program and turn on and off the vsync and do the same to my driver. eventually it would work
