Only some flicker in menus that I have noticed up to this point in other games. Here is Overwatch 2 running at 180 FPS with great frame time and COD at 100 fps and very good times. Any spikes in COD were the start of death cam replays that I was skipping. I am going to chalk this up to Tarkov being Tarkov. But I would love to try and find out what would cause something like this in Tarkov. Especially because it is so consistent and I have seen others mention flicker in Tarkov on this monitor. Maybe I will try to find another Unity built game to test against.jorimt wrote: ↑11 Apr 2023, 13:07
Your frametime performance in that graph is definitely not consistent enough, and will easily cause visible OLED VRR flicker. You're experiencing some serious sawtoothing; the frametime (bottom row) should be much flatter when the framerate is limited by RTSS or Nvidia MFR.
Do you get less VRR flicker in other games, and if so, what do their frametime graphs look like? Because if you aren't experiencing this in other games on the same system (or less so), it's likely game-specific.
OLED 240hz lg-27gr95qe-b and G-Sync Brightness Flicker
Pootklopp
Re: OLED 240hz lg-27gr95qe-b and G-Sync Brightness Flicker
- Overwatch
- ow2-180fps.jpg (18.84 KiB) Viewed 7694 times
- COD
- cod100fps.jpg (33.39 KiB) Viewed 7694 times
- jorimt
Yup, those are normal.
Definitely Tarkov and/or Unity-specific. There's probably a way to remedy it, but since I don't own it, I can't easily determine whether said remedy can be performed user-side, or must be addressed dev-side.Pootklopp wrote: ↑12 Apr 2023, 08:52I am going to chalk this up to Tarkov being Tarkov. But I would love to try and find out what would cause something like this in Tarkov. Especially because it is so consistent and I have seen others mention flicker in Tarkov on this monitor. Maybe I will try to find another Unity built game to test against.
Again, the Unity engine has been known to have issues with VRR:
viewtopic.php?f=22&t=7158&p=53976
