OLED BFI Options?
dickcheneyx
Re: OLED BFI Options?
Post by dickcheneyx » 30 May 2023, 22:26
30 May 2023, 17:54
bumbeen wrote: ↑
30 May 2023, 06:18
wow I had not seen that video, and was very confused until linus showed the bit of the frame floating in black space and then it instantly made sense to me. That is absolutely genius, and it seems like it would even work for multiplayer games like csgo and valorant, although at a higher minimum FPS threshhold that at least matches the tick rate of the game. So 128fps to 1000fps would be quite easy to do here
Even that amazing desktop reprojection video is actually low-quality Wright Brothers stuff. Oculus (I still prefer that name over "Meta") Rift VR does a better job of reprojection with ASW 2.0.
Good reprojection (ASW 2.0) has fewer artifacts than other persistence-improving techniques such as strobing or detail-level reduction (to increase frame rates).
So for those people coming and not realizing we can reduce display motion blur gigantically in a strobeless way (no flicker like CRT / plasma / phosphor / BFI / strobe). Ergonomic flickerfree method of eliminating display motion blur.
Good, properly done reprojection is not frames that are more fake
Pure strobing and pure frames have their place. Especially for retro games. However, the fake-frame dissmiss-artists forgets to acknowledge the above pragmaticness for modern 3D workflows.
Video compression (Netflix, YouTube, whatever) is often 23 fake frames per second and 1 real frame per second, being that said video compression uses interpolation/prediction systems (e.g. the I-Frame, B-Frame and P-Frame system of many MPEG1/2/3/4 codecs, use interpolation mathematics).
It's not black box like laggy TV interpolation, because the video compressor had access to ground truth (original frames) and the game good reprojector logic has access to ground truth (inputread/geometry/zbuffer/etc).
So, the fakeness of the frame, is pretty much synthetic/academic sematics, considering that all GPU frames can meet the Merriam-Webster dictionary definition of "fake" in some aspects (e.g. artisting a photorealistic UE5 frame using triangles (aka polygons) and bitmaps (that we call textures).
Semantically, rendering a GPU frame is still a synthetic frame.
Reprojection is now potentially a "less fake" way of doing ultra high frame rate, because of what I said above.
Reprojection is simply a different workflow of doing something with fewer artifacts than doing it directly via GPU triangles and textures -- we have to lower detail level to make a frame even more fake, to get higher frame rates -- so we can make frames less fake by using reprojection! It can go artifactless like Netflix fake frames. And if it can be lagless for esports, then why not?
Eliminating reprojection artifacts
The artifacts of reprojection can be diminished further by using a base framerate above flicker fusion threshold (aka 100fps starting frame rate), to eliminate even more reprojection-artifacts.
Sample and hold stutter and blur are exactly the same thing. Low-frequency sample and hold shakes/vibrates like a music string -- And high-frequency sample and hold blurs like a fast music string -- www.testufo.com/eyetracking#speed=-1 (look at bottom of UFO as it changes speed over the course of 30 seconds). By pushing ALL frequencies above flicker fusion threshold (starting frame rate, and all jitter frequencies, etc) well up there, reprojection becomes much more artifactless.
Reprojecting 100fps->1000fps is MUCH fewer artifacts than reprojecting 45fps->90fps.
And you have no double-image effect like Oculus, because it's sample-and-hold (no double-impusling)
Sometimes blur is good. Right tech for right job.
Sometimes we love motion blur. Hollywood Filmmaker Mode. Motion blur has the right artistic tool. But it's bad when trying to simulate a Star Trek Holodeck: More blur than real life. So, there you go. Right Tool For Right Job.
We all love artsy looks like Minecraft or retro games, but we also enjoy real-life-style games (e.g. photorealistic shooters), and that's where displays are throwing bottlenecks at us, or artifacts of attempting higher frame rates at low blur (strobe flicker or low-detail ugliness), which reprojection does fix.
See where I am getting at? Wink, wink.
Large-ratio reprojection is a massive motion blur reduction technology
With large-ratios, reprojection can eliminate as much motion blur as strobing can!
The biggest technological catch is that refresh rates and final frame rates need to be stupendously high.
- 500fps for 2ms MPRT strobelessly
- 1000fps for 1ms MPRT strobelessly
- 2000fps for 0.5ms MPRT stroblessly
This is assuming GtG is practically zeroed out, GtG darn nearly 0ms. OLED is able to do that. With 240Hz OLEDs and 500Hz+ LCDs, and refresh rates still increasing (and 1000Hz tests already done in the lab), we're already very close to 1000Hz displays becoming a reality before the end of this decade.
Now that brings the GPU problem. And reprojection solves the GPU problem.
We blur-busting enthusiasts all want 1000fps UE5.2 or UE6 quality graphics eventually.
Reprojection will successfully get us there, and possibly even on some of today's GPUs (e.g. RTX 4090 can do 1000fps reprojection today; confirmed via tests). 75% of an RTX 4090 can be directed to render original UE-quality frames, and 25% of an RTX 4090 can be directed to convert 100fps to 1000fps in a nigh-lagless manner. NVIDIA theoretically could call this DLSS 4, but it also has to be baked into the game engine (due to need for access to inputread/geometry/zbuffer ground truth, for accurate artifact-free reprojection).
Reprojection can rewind local input lag too! Turning 100fps 10ms rendertime lag, to 1000fps inputreadtime lag. This is done by making sure reprojection has access to current ground truth (inputreads) and past ground truth (fully rendered frames with zbuffer and geometry). The current ground truth (mouselook/strafes/etc) morphs the most recent historical frame to current freshest 6dof inputreads.
With a two simultaneous-workflow GPU pipeline (the original-frames pipeline, and reprojection-pipeline), you can convert a varying-framerate game into a permanent constant framerate=Hz experience that is synchronized to freshest 6dof inputreads (mouselook/strafes/etc).
So a fluctuating 80-120fps gets converted to a perfect 500fps@500Hz via a variable-framerate-compatible reprojection engine that has permanent access to continual 1000Hz 6dof data (even between original-render frames). You get the lagless 500fps VSYNC ON look, from an original fluctuating-framerate stream.
The most important two gods of good blur-reducing stutter-reprojecting reprojection
(A) game timestamp is god (microsecond monotonic counters)
(B) inputread timestamp is god (calculating and executing local player 6dof position to sub-millisecond relative accuracy)
As long as (A) and (B) is met, it successfully becomes a DLSS+ULMB+GSYNC sequel.
This is "DLSS+ULMB+GSYNC+FlickerFree+EyeCare" sequel rolled into one.
- DLSS because reprojection is a frame generation tech (even if lagless)
- ULMB because reprojection also reduces motion blur
- GSYNC because reprojection also can de-stutter a variable input framerate to a constant output framerate
- FlickerFree EyeCare because this is flickerless, strobeless, BFI-less, PWM-less.
So it is simultaneously DLSS 4, ULMB 3, and GSYNC 3 rolled into one!
The reprojection processor on the GPU would run at a higher GPU priority than the original frames pipeline, to ensure the framerate=Hz lagless reprojection experience.
Enemy movements may still stutter, but remember the stutter-to-blur continuum -- 100-200fps is just slightly extra persistence blur, not stutter. So enemy movements might look slightly blurrier than the rest of the screen. Reprojection fixes the most important motion blur (global motion blur of panning / scrolling / turning / strafing), which is why reprojection is the prioritized motion blur reduction technology.
So, reprojection (on ultra-high-Hz nigh-instant-GtG displays) will easily make BFI obsolete for some people, since strobless (Flickerfree! Ergonomic! PWM-free!) motion blur reduction is the Blur Busters Holy Grail of sorts for many of us.
We love strobing, but it's still a (good) bandaid for the fact that computer frame rates is finite/synthetic version of real life, and real life is framerateless.
Since large-ratio reprojection technology is a fantastic motion blur reduction technology;
Next Steps for desktop reprojection
Now, the next steps for reprojection I think should be:
NVIDIA and Epic should collaborate to add lagless frame generation to DLSS 4/5 or ULMB3 (via reprojection) to a future Unreal Engine 6.
(or Intel+XeSS, or AMD+FSR, if they have the skill to beat the fabulous NVIDIA gorilla to this punch)
I even told this suggestion NVIDIA directly (to Seth Schnieder during past emails / past meeting), that they need to consider this. I could tell they knew what I was talking about -- there was no confusion. I have no doubt the engineers at NVIDIA are smart. Let's hope.
There is enough computing power in an RTX 4090 to do 1000fps reprojection, and NVIDIA could use the extra sales that reprojection can cause. Even the budget gamer who can only afford a $400 GPU is more likely to buy an RTX 4060 if it can do DLSS4 reprojection to turn 20fps games to 60fps (with some artifacts), while the enthusiasts like me will use an RTX 4090 to turn 100fps RTX ON to 240fps-540fps.
If it's even more stomachable to the beancounters at GPU manufacturers, DLSS4 with reprojection could debut during the 5000-series instead. Okay. I can certainly understand the business case (I'm a business too), even if the users will scream holy hell about not getting easy reprojection on older GPUs, like that famous LTT reprojection video is extolling about.
Heck, I can do Oculus reprojection on an old GTX 1080 GPU, converting Oculus Rift 45fps to 90fps. But, I would still implore NVIDIA to introduce DLSS4 (at least forward reprojection) retroactively to RTX 4000 series.
I feel that NVIDIA does not need to fear sales and revenue reductions -- reprojection will help increase GPU sales by giving more 60-120fps experiences to more mainstream people (including casual gamers), while giving the high end gamers the 500+fps strobeless blur reduction experience.
It can be basic for now, e.g. slightly laggy reprojection that doesn't have rendertime-latency rewind capability at first. The complete ULMB+GSYNC+DLSS combined sequel that is lagless-ready for esports, can come later (e.g. DLSS5 or DLSS6). But the starting pistol of reprojection needs to begin soon -- like 2023. Definitely 2024 at the latest for one of the flagship game engines.
There is little demand now only because nobody knows this as well as Blur Busters does.
Remember our LightBoost HOWTO? Remember our G-SYNC 101? We helped the sales years before many marketing people at NVIDIA realized this. This is BlurBusters' "Big Hit #3" -- we are even about to crowdfund a third party reprojection processor for a desktop game engine. But I'd rather see NVIDIA beat me to the punch. Will be glad to see NVIDIA lift all refresh rate boats, win win even if my project becomes a throwaway project. So, NVIDIA, you heard me. I consider this potential Hit #3 of the mid-2020s after LightBoost HOWTO and G-SYNC 101.
Why am I loud? Big boom of OLED
I've seen the Wright Brothers version of this in action. It's that impressive.
I am actually, in real life, witnessing with my eyes, the tantalizing simultaneous ULMB+GSYNC+DLSS+EyeCare+FlickerFree rolled into one, when framerate=Hz reprojection is executed on a high-Hz OLED.
So, NVIDIA needs to address the boom of OLED, increase GPU sales to OLED purchasers. With gamers kind of frustrated at NVIDIA, this technology would be a major appeasement. Framerate progress should no longer be held back -- RTX ON pathtracing and triple-digit frame rates is currently mostly mutually exclusive -- but it does not need to be.
Today, 240fps reprojection for pathtraced content on today's 4000 series!
Tomorrow, 1000fps ULMB3 replacement.
This is the motion blur reduction and stutter-killing technology of the 2030s.
Strobing will remain important for a long time (especially today's LCD, plus also on retro content that is ruined by frame generation). That being said, framerate=Hz on OLED means that 4ms MPRT on OLED looks better than 2ms MPRT strobed, since the extra biasing factor (The simultaneous "ULMB+GSYNC+DLSS+FlickerFree+EyeCare" effect) puts a gigantic elephant-weight on the motion quality of strobeless motion blur reduction.
The Business Case For Reprojection on OLED
Why is reprojection vastly more effective on OLED?
Why is it potentially very profitable for GPU vendors?
  • OLEDs have massive upgradefeel appearance with reprojection algorithms
    120-vs-240fps is more visible on OLED than LCD, more mainstream people will notice.
  • OLEDs on desktop usually dont have BFI
    Reprojection is a successful alternative
  • OLEDs stutters are more visible at 60fps, requiring 90fps+ to look good
    The ultra fast GtG of OLED makes 60fps more stuttery on OLED than LCD. Reprojection fixes this by going to higher framerate. Some people get motionsick OLED stutters, or from from stutters of turning RTX ON, so having RTX ON at framerate=Hz, in a lagless way via rendertime-rewind-to-inputtime, I believe, visually creates a lagless motion nirvana that leads to more sales all across the board.
  • OLEDs does not have much brightness headroom
    Reprojection does not degrade brightness
  • OLEDs has fantastically fast pixel response and looks great at framerate=Hz
    240Hz OLED has clearer motion than most unstrobed 240Hz-500Hz LCD
And hey, eventually, even VR games will be able to get all that RTX ON goodness, with no framerate compromise! With the new reprojection algorithms that convert a varying framerate input, to a constant framerate=Hz output. So these innovations can be ported back to VR markets too, lifting all Hz boats, and expanding beyond the sales-limiting esports silo, too.
Note: This forum post is about to be converted to a Blur Busters article shortly; I often use my forums as a drafting table for future articles. More than half of www.blurbusters.com/area51 are rewritten/polished/curated versions of my past forum posts here. I intend to fire off a race between all the GPU vendors, even though I am rooting for NVIDIA's brilliant engineers to do it first, helped by their brilliant robot arm pursuit camera
Thank you for this throughly detailed post. I've learned so much here and just want you to know your work is not unnoticed or underapprecited.
Hopefully oleds with better motion come sooner rather than later. Despite my desire to get a new monitor since my 2540 is dying I really don't want this push towards better motion Clairity to die out to some other fad.
blurhater92
Post by blurhater92 » 18 Jun 2023, 06:42
28 Feb 2023, 23:38
Right now AFAIK, the /current/ LG OLED backplanes only supports as low as 4ms MPRT, so if BFI gets added (working on it) it'd only be available for sub-240Hz. I have now gotten information that BFI is coming to at least one 240Hz OLED. Keep tuned!
I would surely buy an OLED gaming monitor with BFI. I understand maybe you can't give specifics, but is BFI coming to an already released OLED monitor via a firmware update, or is this going to be a new OLED monitor launching soon with BFI?
I currently have an LG 65" GX which has excellent BFI, but having a monitor would be nice so I can game while others are watching TV. As of now, I'm hogging up the TV too much. :lol:
Post by Chief Blur Buster » 19 Jun 2023, 01:03
Undetermined, but I can say implementations will be coming.
In general, all 240Hz OLED BFI implementations will only work at 120Hz and under. This is just a limitation of the OLED refreshing backplane, requiring physical blacked-out refresh cycles, to work. OLEDs don't have a separate illumination mechanism (backlight) to control strobing separately, so it's a bit more complicated to get low MPRTs at low refresh rates on OLEDs.
However, this will be great for any 60fps-120fps content. The goal is to enable it for all refresh rates 120Hz and lower.
We are evaluating a separate OLED-specific Blur Busters Approved program (possibly a slightly different color logo) as a compromise to recognize the OLED limitations -- but to acknowledge the need for blur busting lower-framerate material.
elexor
Post by elexor » 19 Jun 2023, 03:37
19 Jun 2023, 01:03
Could you in theory use the panels vrr capability to do fixed hz bfi at non divisible refreshrates =< 120hz on a 240hz panel and gain adjustable mprt. will this be a feature for upcoming 240hz oleds?
scan out the real frame and wait a variable amount of time to start scanning the black frame to achieve variable persistence. if done on the scaler will it be jitter free enough? and i'm assuming you would combo with fixed hz qft
*edited because I got some stuff completely wrong
Post by Chief Blur Buster » 20 Jun 2023, 03:50
Currently, VRR BFI isn't planned at this time. The precision requirements for VRR strobe quality are too difficult, and not included in the scope of work.
HappyHubris
Post by HappyHubris » 21 Jun 2023, 14:58
Two basic questions:
(1) For people who have tried fast IPS, strobing, and OLED 144Hz+, how close is OLED to strobing for blur reduction? Is it a nice stepping stone due to the lighting response times, or is the sample-and-hold blur still obvious and brutal?
(2) I'm surprised that someone hasn't rolled their own BFI for 240Hz OLED by running games at 120FPS and then using a wrapper that inserts one black frame for every rendered one. Surely something like this is possible with reshade?
hart
Post by hart » 08 Aug 2023, 10:39
https://www.reddit.com/r/doughcommunity ... caught_on/
from today
maybe one day they will release the monitor and could be a great allrounder for some time, glossy, 120bfi, and about 900€, cheaper than the competition
may be this one the one which you are working with chief?
Displays: Dell AW2725DF + LG 27GL850B + LG Dual-UP 28MQ780 PSU: Corsair HX850i Mobo: B650E-E CPU: 7800x3D Cooling: Arctic LiquidFreezer III 420 RAM: 32gb DDR 6000 CL28 GPU: Strix 4090 SSD: Samsung 990 PRO 4TB + WD SN850X 2TB Mice: G-wolves HSK pro 4K + Razer Naga V2 pro Keyboard: Wooting 80HE Sound: Topping DX7 Pro+ (using optical) / HifiMan Edition XS / Bose QuietComfort Ultra OS: W10 pro
deama
Post by deama » 02 Sep 2023, 11:38
19 Jun 2023, 01:03
Any predictions on when the limitations may be pushed through? I'm really wanting a 240hz with BFI OLED TV, but from the looks of things, it's nowhere near the horizon.
Or is OLED not the answer to this? Is the next panel technology like miniLED the way?
HappyHubris wrote: ↑
21 Jun 2023, 14:58
I did an implementation for this and wasn't good, issue was that the black frames would overlay ontop of the real frames, so even though it did look smoother/clearer, it actually gave it a weird affect, like you were missing frames if that makes sense, this weird "glide" effect, hard to describe.
You would have to write a dedicated software piece that would have to somehow talk to the monitor to do it properly, nevermind asking the manufacturer of the monitor to even implement a way to talk like that (could easily break the monitor).
NeonPizza
Post by NeonPizza » 09 Sep 2023, 13:11
One thing that's irritating with the LG C1's 120hz BFI, is that it's motion Pro low, medium & high settings, again when gaming at 120fps, gradually causes this weird unnatural harsh darkening(Not talking about brightness loss) with the image, the higher your go. I'm not entirely sure if it's shadow detail crushing or what but it looks awful. Is there a way to correct this?
For now, I just roll with vanilla 120fps. However 120fps+MPLow(Using the module HDR 'ON' setting in the service menu) manages to retain enough brightness to make it worth while, but once you get to High and even medium, the brightness just doesn't quite cut, at least for me personally.
Chamber
Post by Chamber » 10 Sep 2023, 05:46
NeonPizza wrote: ↑
09 Sep 2023, 13:11
You can improve near-black visibility on the LG C1 with OLED Motion Pro High using Reshade. Plasma TV for Gaming made a great tutorial showing how: https://www.youtube.com/watch?v=5MyVfNWTewM. If you have any issues or findings you can let him know, as he reads all comments.
