Re: VG279QM still worth it in 2023 ?
Posted: 18 Aug 2023, 17:36
_______________________________Sirius wrote: ↑16 Aug 2023, 22:39
For CS:GO/Valorant usage, it is probably a good choice for the price but if you play at other games like Apex Legends, Overwatch or even Battlefield, avoid this monitor.
It's just my personnal experience ( even if certain point are totally objective ) but i can't recommend this monitor at all, i feel it is a little bit overrated.
At first I didn't pay attention to 1080p on this 27inch, I forced myself and said to myself (man you'll get used to it and after that it will be normal) where actually, TN panel , I "can" get used to, the 27 inch 1080p, no, absolutely not.
On this screen I just feel like I'm so stupid as if my brain didn't react, I tried with different keyboards, different mice, different PCs, always the same, I feel stupid and at times I don't react to the enemy, everything is "troubled" whatever it is with or without anti-aliasing.
There is what i see when i play ( An absolutely garb*ge image quality ) :
Ok, i think i read the most threads here about this monitor. It is the 27" Monitor ASUS VG279QM and i speak only as a User of this screen
and not a professional. I had a samsung 60 hz monitor and after that a Lenovo G27q-20 165 hz.
I felt that I was always at a bit of a disadvantage with the Lenovo in fortnite compared to players with a 240 Hz monitor or even higher.
That's why I now have the Asus with 280 Hz.
The first impression was really very good and I had the feeling that I see everything faster and better. However, after playing the monitor for about 2 months now, I have the same feeling as Sirius.
When it comes to very fast scenes, which are the rule in Fortnite, especially in No BUILD and you wildly speed with the mouse over the entire mouse pad I have the impression I see nothing at all. Even enemies in the distance are almost impossible to see and even when they shoot at me, it takes me far too long to see them at all. I have now tried all the settings that are available on this monitor and will get another one. It has a great picture when set up correctly but as soon as there is fast movement or something in the distance, I just can't get it right.
This is just my own impression as a normal user and not as a monitor specialist.
G-Sync makes it a bit better but i am an old far* with a old system. I need every millisecond I can get
