Page 4 of 16
Re: New Zowie Monitor 540Hz XL2586X
Posted: 23 Mar 2024, 18:34
by Falkentyne
daviddave1 wrote: ↑12 Mar 2024, 04:09
möppeldöp wrote: ↑08 Mar 2024, 07:38
You can of course compare Hz 480 on Oled vs 540 on IPS or TN. I can tell you that most likely the Oled will win this comparison.
However, if you put motion clarity into your consideration, BLS / BFI is by far ahead on IPS or FastTN. If you care about colors, go buy Oled, if you care about motion clarity for precise vision/aim go buy a Product with blacklight strobing.
I clearly believe the XL2586X with DyAc2 is superior over all other technologies (ULMB2 & OLED & OLED BFI).
The 27" 480hZ 1440P ASUS OLED will have a backlightstrobing tech. See the
https://www.youtube.com/watch?v=bjdJjPd ... QwOQ%3D%3D video with the ASUS USA guy. I am courious how bright the monitor will get in SDR. The ASUS USA guy do says something about gamers who like brightness ( like me) he says something like if you really like brighntess other monitor tech suits more. Guess we have to wait and see.
What is the lower BFI limit? Is 60hz possible?
Posted: 26 Mar 2024, 14:02
by daviddave1
Posted: 27 Mar 2024, 03:47
by daviddave1
Posted: 27 Mar 2024, 04:51
by forcedreg
No price cut for EU it seems, how much was it in US previously?
Posted: 27 Mar 2024, 12:00
by daviddave1
forcedreg wrote: ↑27 Mar 2024, 04:51
arround 1179$
Posted: 28 Mar 2024, 00:42
by Falkentyne
daviddave1 wrote: ↑27 Mar 2024, 12:00
arround 1179$
Dave, I asked above, what is the lowest refresh rate their BFI will work at? (on the Asus OLED, NOT the Zowie double strobing mess?).
Posted: 28 Mar 2024, 08:38
by daviddave1
Falkentyne wrote: ↑28 Mar 2024, 00:42
arround 1179$
Sry for the later anwer. I have no idea what the lowest BFI possible will be on the ASUS OLED 1440P 480 27" Its still in the works.
Posted: 30 Mar 2024, 13:21
by Falkentyne
daviddave1 wrote: ↑28 Mar 2024, 08:38
arround 1179$
Thank you.
Posted: 06 Apr 2024, 04:43
by daviddave1
It seems that u cannot disable DSC on this monitor... why use HDMI 2.1 then? My pg248qp does have this option. This will prob be a dealbraker for me...
Posted: 08 Apr 2024, 06:30
by Jianhu
As far as I know, you can switch to EDID 500HZ in the XL2586X OSD, which will disable DSC.
So this is optional: 540Hz with DSC / 500Hz without DSC.
