LG 27” 1440P 480Hz OLED CES 2024
Dalek
Re: LG 27” 1440P 480Hz OLED CES 2024
Post by Dalek » 25 Sep 2024, 02:55
Boop wrote: ↑
24 Sep 2024, 15:28
Dalek wrote: ↑
21 Sep 2024, 14:04
To any PG27AQDP owners, are there any drawbacks or dealbreakers with this monitor?
Check out the TFTCentral review.
I have no complaints with mine. I haven't tried using VRR and BFI very much though. I'm primarily using it for competitive games with uncapped framerates.
What about text clarity? Is it ok for general day to day use of reading or not so much?
jetcat3
Post by jetcat3 » 30 Sep 2024, 14:55
Yes, definitely an upgrade over the first gen MLA WOLED panels and a bit better than Gen 3 1440P QD-OLED.
forcedreg
Post by forcedreg » 10 Oct 2024, 10:11
There's an option in OSD of PG27aqdp to disable DSC, but then the 480hz option disappears for all resolutions. Anyone have an idea how to enable for example 1024x768 @ 480hz when DSC is disabled? HDMI 2.1 should easily have bandwidth for that without DSC.
EDIT: Nevermind, simply creating a custom resolution in nvcp seems to work... Display scaling however doesn't seem to work as the active signal resolution and desktop resolution doesn't match.
EDIT2: Was able to fix that as well with CRU. :P
Baron of Sun
Post by Baron of Sun » 11 Oct 2024, 01:22
forcedreg wrote: ↑
10 Oct 2024, 10:11
Would you tell how to fix that? I have the PG27AQDP as well and I cannot select 480 Hz (or rather 479.989 Hz in windows 11, don't know why) with DSC disabled. I have the firmware MW103. I also cannot enable VRR with DSC enabled in windows, so I cannot use the VRR range above 240 Hz then.
forcedreg
Post by forcedreg » 11 Oct 2024, 03:58
Baron of Sun wrote: ↑
11 Oct 2024, 01:22
forcedreg wrote: ↑
10 Oct 2024, 10:11
I'm running Win10, haven't updated the firmware. I just created custom resolution at nvidia control panel: from the left menu Display - change resolution and then scroll down and click customise - create custom resolution.
