Display Hot Keys - Instantly apply display settings with hot keys!
Talk to software developers and aspiring geeks. Programming tips. Improve motion fluidity. Reduce input lag. Come Present() yourself!
jon-mil-92
Re: Display Hot Keys - Instantly apply display settings with hot keys!
Post by jon-mil-92 » Today, 17:08
Display Hot Keys 4.5.0 Release:
This minor release translates Display Hot Keys into ten languages, adds a language setting, and fixes the main window opening behind other windows.
New Features
  • Added language support for English, German, Spanish, French, Italian, Brazilian Portuguese, Russlan, Japanese, Korean, and Simplified Chinese. This covers the main window, the dialogs, the notification area menu, the info overlay, and the key names.
    Added a Language setting under the new Customization section of Additional Settings, so you can switch languages without restarting the app.
  • The installer now lets you pick one of the ten languages. After every install, the app uses the language you picked, and the uninstaller uses it too.
  • The portable package now starts in your Windows display language, or in English if that language is not supported. Its "uninstall.bat" cleanup now runs in the app's language.
Improvements
  • The app now draws each language in its Windows font, so Japanese, Korean, and Chinese text uses the correct characters.
  • The main window, dialogs, and notification area menu now size to their text, so every translation fits at any display scale.
  • The Additional Settings, About, and License windows now stay open in the same place when the app refreshes (such as after changing the language or connecting a display).
  • Hot keys are now shown without spaces around the plus sign (such as "Ctrl+Shift+F1").
  • The Orientation options now match Windows Display Settings: "Landscape (flipped)" and "Portrait (flipped)" replace "iLandscape" and "iPortrait".
Bug Fixes
  • Fixed the main window opening behind other windows when the app is started from the desktop shortcut.
  • Fixed the column headings cutting off their last letter at some display scales.
Creator / developer of Display Hot Keys: https://jon-mil-92.github.io/DisplayHotKeys/
Instantly apply display settings with user-defined hot keys!
