Recently it is said that the MAG version (700$) allow you to upgrade firmware, according to recent reviews.
Having said this, there's no major reason to buy the expensive one, right? Since the QD OLED panel is the same, without any difference
Monitor Hz not matching FPS
- RealNC
Re: Monitor Hz not matching FPS
Yes, same panel. The extra features do not affect image quality.
Dreamer19
Just ordered the mag version.
Which connector should i use? HDMI 2.1 or DP 1.4?
Both of them can achieve 360hz 1440p, so i don't know what's he difference between them.
