Re: Timer Resolution from 15ms to 1ms [Turn 60Hz-feel into 240Hz-feel on 240Hz]
Posted: 23 Sep 2024, 23:37
Why do you think RTC is default? Do you have any source of information?
W10 before 2004 version, timer shows RTC=0,5/1 and TSC=0,496/0,996. W11 shows equal values.
I have W11, bcdedit by default with timer=1,0000, measuresleep shows Sleep=1,996x constantly, and timer=0,5000 shows Sleep=1,494.
Now, I set useplatformtick yes, with timer=1,0000, measuresleep shows Sleep=1,996x but also unstable lower values, and timer=0,5000 shows Sleep=1,5 which is the sum of both. Bcdedit default has Sleep=1,494 which means RTC is not the one being used.
Also, seems RTC can't have Sleep lower than 1,5 with timer at 0,5xxx (0,51 as a safe value). This is what @JimCarry is experiencing.
Anyway, I always felt the timer at 0,5 seems to create a weird delay and games/apps already set the timer to 1ms which is what they need and is enough, so it's kind of pointless to set it any lower.
If TSC is default like I think it is, then 'disabledynamictick yes' should actually help.
