Final desync/hitreg fix with truly unexpected cause
spkii
Re: Final desync/hitreg fix with truly unexpected cause
Tell after 2 days or 3 if still working, curious solution...
cursed-gamer
- Slender
The bracelet on the left hand should be connected to the metal base of the table, the bracelet on the right hand to the PC case. Your feet should be directly connected to ground. Then it will be 100%
- Z3CrosS
I think that i don't think
MontyTheAverage
I believe the body theory.
cursed-gamer
and it still works. I see no reason to check another regedit tweaks thread over and over.
