netsh int tcp set global autotuninglevel=disable
Re: netsh int tcp set global autotuninglevel=disable
Post by Slender » 06 Feb 2025, 06:15
Slender wrote:
06 Feb 2025, 06:09
oh yeah, I forgot to say. autotuning=disable allows you to prevent packet loss in the game when downloading any files in the background.
also disable decrease bufferbloat result
Syykfk
Post by Syykfk » 30 Mar 2025, 05:37
JimCarry wrote:
28 Jan 2025, 08:25
hirecuery wrote:
27 Jan 2025, 19:47
Slender wrote:
27 Jan 2025, 13:27
yeah try ctcp
idk why its default, i installed ctcp above. driver problem?
I dont really understand you,but if you want to make ctcp and its not working via cmd / powershell command and you are on win 10 you need reg file executed by power run,i try all cmd powershell command it cant be changed to ctcp,the moment i executed the reg file and restart pc, its ctcp as you see in the screen i provide above.
Could you provide the registry file you set as CTCP?
JimCarry
Post by JimCarry » 30 Mar 2025, 17:53
Syykfk wrote:
30 Mar 2025, 05:37
JimCarry wrote:
28 Jan 2025, 08:25
hirecuery wrote:
27 Jan 2025, 19:47
Slender wrote:
27 Jan 2025, 13:27
yeah try ctcp
of course big man.as i said i try every single way of chaning,bcdedit commands ,powershell,going to regedit by hand,nothing works except making this on reg file and executing it via powerrun.
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Nsi\{eb004a03-9b1a-11d4-9123-0050047759bc}\0]
"0200"=hex:00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,02,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,ff,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
"1700"=hex:00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
