Page 4 of 4
Re: Modify multicast in optical modem to less desync and hitreg
Posted: 15 May 2025, 14:28
by JimCarry
Syykfk wrote: ↑15 May 2025, 03:31
JimCarry wrote: ↑14 May 2025, 02:24
i buy usb nic because i read here is better,and it is,but you are not using usb nic you are using on board,so please try this for the last time,you feel msi off is not good because you have rss on,go turn off rss (or at least if you gonna use it,at least use it properly change maximumnumberofrssqueues from 1 to 4),so 1.turn off msi mode for nic 2.change priority to undefined 3.turn off rss in advanced 4.bind nic to core 5.restart pc 6.go in this program and post screenshot here to see that the nic is bin to a core ,i give you an example i have 7600x no smt,i was using this before the usb nic.
so this is how my pc looks like NOW,as you can see you cant see realtek 2.5gb because i disabled in bios and i am using usb nic,but before that nic was there i bind it to core 5(only core 5 was showing in this program after realtek 2.5g like nvme for example) ,and after that my friend cs2 was running smoothly.try it if you do exactly how i describe they must be diffrence 10000000%, also i use the latest realtek driver from the official site(no power saving driver i click on it) it was from 2025 i think!and everything in advanced disabled not like yours.
ok if you did this and you still dont like it then i will show you how it must looks your way.(second pic is for that case)
I will conduct more tests to check the desync with RSS turned on and off.
Is your suggestion to turn off RSS?
i wrote what i wanted to sugest you are doing only 1 of the thing,as you wish.i try to delete it but i cant.
Posted: 15 May 2025, 14:37
by JimCarry
Syykfk wrote: ↑15 May 2025, 02:03
JimCarry wrote: ↑13 May 2025, 00:53
sorry if i am being annoying but i still cant understand your screen because of the language barrier, i am i right place or in the wrong ? first i click on WAN then i must click NEW ?
You are in the right place.
Choose the connection you are currently using in the WAN section.Then check 'Enable nat' in the IPv4 information, and change the nat type to: Full Cone NAT.
I connect my PC directly to the optical modem, without going through a router.You can use NatTypeTester.exe to test whether your nat type is Full Cone NAT.
Thanks,can you answer me this:
1.Did i do it ? i provide screenshots
2.before making this thing in WAN sectionn,my tv was on 200 priority and internet was on 100
3.can i delete old internet
4.what should my priority be?
5.in your screen you selected lan 4,my cabble from router to pc is in lan1.
Posted: 16 May 2025, 01:34
by Syykfk
1. You did it.
4. I have not changed the priority, keeping it default.
5. lan4 is just to ensure I can connect to the network normally, with no special function.
Posted: 16 May 2025, 01:58
by JimCarry
Syykfk wrote: ↑16 May 2025, 01:34
1. You did it.
ok thanks again,is it possible to be better without the wan settings i just did ?
Posted: 16 May 2025, 03:50
by Syykfk
I don't know,
I only adjusted the ones I mentioned, and kept the other settings as default,
I didn't adjust any settings I didn't mention, you need to test
Posted: 16 May 2025, 14:06
by JimCarry
Syykfk wrote: ↑16 May 2025, 03:50
I don't know,
ok thanks again,i only change the one you show + i turn off lights.
