Page 4 of 7
Re: BenQ XL2420G Release Info
Posted: 14 Nov 2014, 17:52
by Alexious
ciopenhauer wrote:I played LoL, HOTS, SC2, D3, Crysis 3, CS:GO, Hearthstone. I don't know what to say about G-sync except that it works as advertised. But my own setup gives me good FPS in everything I play (60+), so I can't really say much about lower frame rates, I didn't go through the process of forcing some caps at lower numbers to see how G-sync performs in those situations.
Yes, you can switch the Engine with one touch button on the monitor. It's easy. Would be better if the S-Switch worked with G-sync though.
EDIT: I just tried playing Crysis 3 with FPS capped at 45. It was very smooth. Nothing quite like the fluidity of 144hz + 144 fps, but no stutters or anything annoying.
Thanks for the reply. Indeed, most of those games aren't that intensive. I have an i7 3770 and 780Ti, mostly fluctuating from 40 to 55-60 fps with all settings maxed generally, but stuttering is a very annoying problem that I'd like to get fixed with GSYNC.
How are the colors, by the way? I have an IPS screen right now, I know that by switching back to a TN I would lose some quality but if GSYNC really works as advertised than I'd do it.
Posted: 14 Nov 2014, 20:09
by ciopenhauer
Coming from a Dell Ultrasharp H-IPS panel, I have absolutely no complaints now. They were horrible at first in Classic mode without Display Pilot + Standard preset, but it's fairly easy to get them to look great. In G-sync mode they look good right away. I just bump the digital vibrance slightly.
Posted: 16 Nov 2014, 11:38
by Alexious
Damn, the Amazon sale expired, it's back t $600 now. But I need to sell my current monitor first...
Do you think the XL2420G will be $530 again during Black Friday?
Posted: 18 Nov 2014, 19:31
by hbjdk
whitestar wrote:And where is the XL2720G? Lost in another dimension?
I e-mailed BenQ a few days ago, asking when it would become available in Denmark, Europe.
Here's the reply I got:
"Thanks for asking! Today I have no confirmed date when we will launch this product in Denmark or Europe (launch will be at the same time across Europe). Target is during Q1 2015."
Then I asked about the XL2420G release date and got this reply:
"Plan is during December
The design will be same as current Z-series (XL2420Z) but with GSync added"
Posted: 19 Nov 2014, 03:50
by 0134RY73
Alexious wrote:ciopenhauer wrote:I played LoL, HOTS, SC2, D3, Crysis 3, CS:GO, Hearthstone. I don't know what to say about G-sync except that it works as advertised. But my own setup gives me good FPS in everything I play (60+), so I can't really say much about lower frame rates, I didn't go through the process of forcing some caps at lower numbers to see how G-sync performs in those situations.
Forget 40 to 55-60 your going to need to be turning down all that eye candy because 144Hz G sync is as smooth as butter if the game is properly coded
Posted: 21 Nov 2014, 04:36
by Alexious
hbjdk wrote:whitestar wrote:And where is the XL2720G? Lost in another dimension?
Could you let me know what email address you used? I've tried reaching them without any success so far.
Thanks!
Posted: 21 Nov 2014, 04:53
by gamerscore
Wish they release a G-sync upgrade kit for us XL-Z series users. But that will be unlikely.
Posted: 21 Nov 2014, 13:07
by Alexious
Alexious wrote:hbjdk wrote:whitestar wrote:And where is the XL2720G? Lost in another dimension?
Thanks!
What's the minimum required amount of posts in order to view PM?...
Posted: 21 Nov 2014, 13:17
by hbjdk
Argh, can't you read PM in here when you're new? What's the reasoning behind that rule?
Anyway, I suppose the Benq guy's e-mail address is not exactly top secret, hush hush, for your eyes only etc.
This is the guy:
Stefan Dahlqvist <
[email protected]>
Posted: 21 Nov 2014, 16:43
by ciopenhauer
0134RY73 wrote:Alexious wrote:ciopenhauer wrote:I played LoL, HOTS, SC2, D3, Crysis 3, CS:GO, Hearthstone. I don't know what to say about G-sync except that it works as advertised. But my own setup gives me good FPS in everything I play (60+), so I can't really say much about lower frame rates, I didn't go through the process of forcing some caps at lower numbers to see how G-sync performs in those situations.
This is true, being able to have 130+ fps is amazing with 144hz, but trust me, even with low FPS, the experience is
drastically different with G-sync. There is absolutely no stutter at lower fps.
