I have a Soundblaster G5. It's interesting to hear where the conversation will go.Jadzira wrote: ↑03 Jul 2025, 01:48
Conclusions:
All sound effects have been disabled. External sound cards from Astro and Creative introduce noticeable latency — enemies visibly appear on screen with a delay. The game runs most smoothly and responsively when using the internal sound card, but only with drivers provided by the motherboard manufacturer. Drivers downloaded directly from the Realtek website (newer) also introduce some delay, though not as much as external sound cards. It’s driving me crazy — you can’t enjoy better sound quality because of the massive delay it causes on the monitor.
DPC latency issue
MeveSPB
Re: DPC latency issue
dsavovic25
It might be worth making a new topic about the issues you are having. Just a suggestion.Jadzira wrote: ↑03 Jul 2025, 01:48Damn! I just discovered this recently — something is wrong with the AM5 platform. When I use an external sound card, the game becomes noticeably less responsive and additional input/display delay occurs.
Let’s go into the details.Conclusions:
- Motherboard: Asus ROG STRIX X670E-E GAMING WIFI
BIOS: 3112
CPU: Ryzen 9800X3D
GPU: RTX 5070
RAM: 2x16GB 6000 MHz CL30
System: Windows 11 24H2 Compilation 26100.4484
Headset: Astro A40 Gen4
Tested external sound cards:
Creative Sound Blaster X4
Astro Pro TR Mixamp
Tested internal sound card: ALC 4080
I tried multiple USB ports — no fix.
I disabled the internal sound card in the BIOS while using the external one — no fix.
I set interrupt affinity (1 core and 1 thread, since Hyper-Threading is enabled) to the USB controller connected to the external sound card — no fix.
I also tested with drivers from the manufacturers' websites as well as the default Windows drivers — no fix.
I keep bios up to date and had many versions so far - still no fix.
Different motherboards didn't fix the issue, I tested Asrock B650E Taichi Lite and X870 Tomahawk.
Does anyone know how to solve this?
- kyube
jax0n99
anyone who can help me with DPC latency for a donation ?
MxD
Did you try setting the interrupt priority of your graphics card to High?
It sound like it could be related to a bug where the (core) clocks on AMD RX cards periodically jump to maximum.dsavovic25 wrote: ↑29 Jun 2025, 07:01Quick update:
This is the latencymon test but without an AMD gpu driver. It behaves almost perfect, I mean, how it should while nothing is working at least. Now, I'm thinking that this is either AMD's fault or a hardware issue. But I've never had any issues with my GPU, so.. There are a few things I will test.. One of them is Amernime drivers and the other one is a clean driver but debloated with Radeon Slimmer..
