2025 Anti lag guide in getting new PC and hardware [video proof]
themagic
Re: 2025 Anti lag guide in getting new PC and hardware [video proof and no schizo BS]
Post by themagic » 10 Oct 2025, 11:39
donger wrote: ↑
10 Oct 2025, 11:32
themagic wrote: ↑
10 Oct 2025, 11:19
Your Game works very fine...playable. enjoyable... :lol:
other than getting clown teams and -100 fps because of the stream i can't complain
Like i saw some moments in your Gameplay where you should get kill but it dont happened...
You saw this too ? But it was rly rare and like 2 or 3 moments or maybe even more ?...
But at all overall you performed very good...Like i dont saw many issue other than that.
donger
Post by donger » 10 Oct 2025, 11:47
themagic wrote: ↑
10 Oct 2025, 11:39
donger wrote: ↑
10 Oct 2025, 11:32
themagic wrote: ↑
10 Oct 2025, 11:19
thb i never judge before watching my recording in 120 fps framy by frame analysis then i call bullshit or not because in 99% of cases after watching in the recording in slowmo it's a skill issue
look what they wrote about BS the too fast TTD they tried to fix this after the beta but i can tell they didn't full fix it, it still happens very much less than in open beta. But they will fix it since it doesn't happen in BF5 like at all. It's still games fault not pc/connection issue.
ManWhoSoldTheWorld
Post by ManWhoSoldTheWorld » 10 Oct 2025, 21:28
donger wrote: ↑
30 Sep 2025, 08:58
If you want your inputlag to be like on the video, read on:
Thanks for sharing your setup and showing what's working for you.
Followed your steps exactly, and sadly CS2 is not any more playable than before.
donger
Post by donger » 11 Oct 2025, 07:17
Then it's probably your ISP but without a video it's hard to tell.
Unreazz
Post by Unreazz » 11 Oct 2025, 13:38
If you can't hit shiet then probably it is yeah. but you are doomed anyways if its ISP since there is not much what you can do besides of switching ISP with other devices. in germany we are out of luck since every phone discriber line is telekom and all devices belong to them. The other providers are just resellers, besides if its Fiber
ManWhoSoldTheWorld
Post by ManWhoSoldTheWorld » 12 Oct 2025, 12:45
Unreazz wrote: ↑
11 Oct 2025, 13:38
If you can't hit shiet then probably it is yeah. but you are doomed anyways if its ISP since there is not much what you can do...
Moving in to a new flat, in two weeks, where the Internet access is delivered from my own company - Let the debugging begin!
Unreazz
Post by Unreazz » 13 Oct 2025, 06:46
ManWhoSoldTheWorld wrote: ↑
12 Oct 2025, 12:45
Unreazz wrote: ↑
11 Oct 2025, 13:38
Keep us updated pls
donger
Post by donger » 11 Nov 2025, 16:54
MouseDPI876 wrote: ↑
22 Oct 2025, 06:56
That’s a really impressive setup — you clearly spent a lot of time fine-tuning every part of your system for low input lag and consistent frame pacing. I totally agree that a clean Windows environment and balanced polling rate make a big difference.
I’ve also been experimenting with different DPI levels and polling rates using Mouse DPI Analyzers, and it really helps visualize how sensitivity changes affect aim stability. Running around 1500–2000 DPI with 2000 Hz polling seems to give that “one-with-the-machine” feel you described.
Thanks for sharing such a detailed build — this kind of data-driven testing is what keeps the community improving.
Aaaand there is another bugged ass game on the market, not working properly unless you use 125Hz mouse LMAO!!
https://www.mouse-sensitivity.com/forum ... nsitivity/
Glad u liked the build, small update Battlefiedl 6 and Arc riders are working flawless.
akylen
Post by akylen » 11 Nov 2025, 19:47
12 Oct 2025, 12:45
Unreazz wrote: ↑
11 Oct 2025, 13:38
Updates ?
ManWhoSoldTheWorld
Re: 2025 Anti lag guide in getting new PC and hardware [video proof]
Post by ManWhoSoldTheWorld » 12 Nov 2025, 08:54
akylen wrote: ↑
11 Nov 2025, 19:47
12 Oct 2025, 12:45
Unreazz wrote: ↑
11 Oct 2025, 13:38
Updates ?
Hi! Yes 🙂
After connecting the new access router in the newly built flat, the Internet Exchange is now just one hop away. I’ve got very effective routing toward the global IP Transit and associated networks. However, RTTs have doubled to Frankfurt and are 60–80% higher to Amsterdam and London. It turns out that some of my traffic isn’t going through the IP Transit but instead takes direct peering paths — which, while intended for more efficient routing, actually performed worse in this case.
The company I work for owns all the network infrastructure (Access, Metro, and Core), so I’ve been able to debug it quite thoroughly. It seems we have some buffering on the border nodes handling direct peering. Long story short → we’re upgrading those border nodes, and I’ve optimized the peering routes toward all Faceit CS2 servers in Europe.
With default Windows settings, I get a bufferbloat grade of “A.” By lowering the PCIe NIC RX and TX buffers, it improves to A+. I can comfortably hold angles in CS2 when connected via the IP Transit path, but when traffic goes through the direct peering route, it’s unplayable. Hopefully the ongoing remediation steps will fix that.
Aside from the network side, I’ve also noticed some odd behavior in the render pipeline. It seems like Windows performs a link training during boot that ignores my monitor’s custom timings — easily fixed by restarting the driver, but still strange. It’s a new and exciting experience every time I boot the computer.
