Page 4 of 9
Re: Try my new app to fix input lag (cs2_timer_fix_by_yam1ke)
Posted: 19 Dec 2025, 04:55
by MK92
Lol another "tweak", when will you people realise that you are not supposed to "fix" ANYTHING in windows, bios, anywhere, you simply install windows, update it to the latest version, update the drivers, and you are good? If you still have issues, there are only two options then:
1. One hardware component is faulty and needs replacament, or
2. Electricity / EM / other interference problem.
Thinking that some random file will fix you this issue, is like trying to download more RAM to your PC :lol: the issue is NOT software releated in ANY way, its the same shit in bios and linux as well, now stop with pointless "fixes and tweaks".
Posted: 19 Dec 2025, 05:53
by urikawa
Somehow its does something thank for your work :) and for the program use kernel calls with some functions like
NtSetTimerResolution
AvSetMmThreadCharacteristicsA
GetAsyncKeyState
SetThreadAffinityMask
SetThreadPriority
Stop being short minded we ll have resintall 100 time the windows system to find more tuning, this program alter some kernel call and offset timer settings to align gpu / cpu its a very interesting way to find another path to enhance gaming session
What i like in that forum there is always someone trying to find something new and share his idea and we debate about it.
And if you want more detail on what is does you can setup sysmon with this xml to be able to see in event viewer the detail :)
https://github.com/SwiftOnSecurity/sysmon-config and a tutorial to use it https://www.youtube.com/watch?v=hM-SJ-X_-sI just filter on the exe :)
Posted: 19 Dec 2025, 06:25
by Lev1n
MK92 wrote: ↑
19 Dec 2025, 04:55
Yes yes everything is related to electricity :lol:
Posted: 19 Dec 2025, 07:04
by MK92
Then why are those "fixes" not working for 95% of people, while for the remaining 5% its just placebo :lol:
EVERYTHING is hardware / outside interference related, NOTHING is related to some fucking obscure windows settings, or how many times will you people mess around with those bcedit userplatformclock bullshit, before realising that this doesn't do ANYTHING as those commands are only relevant for Windows 7 and earlier ??
Posted: 19 Dec 2025, 08:02
by yam1ke
urikawa wrote: ↑
19 Dec 2025, 05:53
GetAsyncKeyState
SetThreadPriority
Thanks, appreciate your adequate point of view!)
Posted: 19 Dec 2025, 08:13
by Lev1n
MK92 wrote: ↑
19 Dec 2025, 07:04
Basically you are saying you are delusional the fix is placebo. Finally i can enjoy the game after 200 windows installs used every tweaks out there. I didnt change anything on my pc(9800x3d,4080 super,6kcl30 rams) only used this config and its night and day difference. If you think something suddenly got fixed in my house you are the delusional one. Just leave us alone let us be happy while we fixed our issues.
Posted: 19 Dec 2025, 08:16
by urikawa
it's you ? https://www.twitch.tv/gr0mjkeee/clip/Co ... ye?lang=it :p
what technique do you use ? corehoping ? its switch the core used to play how does it work ?
in rust what i have cooked instead of c++
THIS CODE is PROVIDED AS IS you it at your own risk !!
cargo.toml
Code: Select all
[package]
name = "cs2_optimizer_architect"
version = "0.5.0"
edition = "2021"
[dependencies]
rand = "0.8"
windows-sys = { version = "0.48", features = [
    "Win32_Foundation",
    "Win32_System_Threading",
    "Win32_Media",
    "Win32_UI_Input_KeyboardAndMouse",
    "Win32_System_SystemInformation",
    "Win32_System_Performance" // Pour QueryPerformanceCounter
the rust main.rs
Code: Select all
use std::thread;
use std::time::Duration;
use std::io::{self, Write};
use std::ffi::CString;
// --- IMPORTS ARCHITECTURE (INTRINSICS) ---
#[cfg(target_arch = "x86_64")]
use core::arch::x86_64::{
    _mm_mfence, _mm_pause, _rdtsc, // Instructions bas niveau
    _mm_set1_ps, _mm_sqrt_ps, _mm_add_ps, // SSE
// --- IMPORTS WINDOWS ---
use windows_sys::Win32::UI::Input::KeyboardAndMouse::*;
use windows_sys::Win32::System::Threading::*;
use windows_sys::Win32::System::Performance::{QueryPerformanceCounter, QueryPerformanceFrequency};
use windows_sys::Win32::Media::timeBeginPeriod;
#[link(name = "ntdll")]
extern "system" {
    fn NtSetTimerResolution(Desired: u32, Set: u8, Current: *mut u32) -> i32;
    fn NtDelayExecution(Alertable: u8, DelayInterval: *const i64) -> i32;
#[link(name = "avrt")]
extern "system" {
    fn AvSetMmThreadCharacteristicsA(TaskName: *const u8, TaskIndex: *mut u32) -> isize;
    fn AvRevertMmThreadCharacteristics(Handle: isize) -> bool;
// --- ÉNUMÉRATION DES MODES DE CHARGE ---
#[derive(Clone, Copy, PartialEq)]
enum LoadMode {
    SSE = 0,
    RND = 1,
    MEM = 2,
    MATH = 3,
    CACHE = 4,
impl LoadMode {
    fn from_u8(v: u8) -> Self {
        match v % 5 {
            0 => LoadMode::SSE,
            1 => LoadMode::RND,
            2 => LoadMode::MEM,
            3 => LoadMode::MATH,
            4 => LoadMode::CACHE,
            _ => LoadMode::SSE,
    fn as_str(&self) -> &str {
        match self {
            LoadMode::SSE => "SSE",
            LoadMode::RND => "RND",
            LoadMode::MEM => "MEM",
            LoadMode::MATH => "MTH",
            LoadMode::CACHE => "CCH",
// --- ÉTAT GLOBAL ---
static mut STATE_HZ: u32 = 5000;
static mut STATE_MMCSS: bool = false;
static mut STATE_MMCSS_HANDLE: isize = 0;
static mut STATE_SCRAMBLE: bool = false;
static mut STATE_CORE: usize = 1;
static mut STATE_FENCE: bool = true;
static mut STATE_PHANTOM: bool = true;
static mut STATE_LOAD_MODE: u8 = 0; // 0=SSE par défaut
static mut STATE_BURST: bool = false;
// --- MOTEUR DE TEMPS ULTRA-PRÉCIS (QPC/RDTSC) ---
fn get_time_us() -> u64 {
    unsafe {
        let mut freq = 0;
        let mut count = 0;
        QueryPerformanceFrequency(&mut freq);
        QueryPerformanceCounter(&mut count);
        // Conversion en microsecondes sans perte de précision flottante
        (count as u128 * 1_000_000 / freq as u128) as u64
// --- MOTEUR DE CHARGE ARCHITECTURAL (CPU STRESS) ---
// Simule les instructions spécifiques trouvées dans l'outil
unsafe fn run_architectural_load(mode: LoadMode, iterations: u64) {
    match mode {
        LoadMode::SSE => {
            // Calculs vectoriels (Simule la charge graphique/physique)
            let mut a = _mm_set1_ps(123.456);
            let b = _mm_set1_ps(789.101);
            for _ in 0..iterations {
                a = _mm_sqrt_ps(_mm_add_ps(a, b));
            // Empêche l'optimisation du compilateur (Black Box)
            std::ptr::write_volatile(&mut a as *mut _, a);
        LoadMode::MATH => {
            // Calculs entiers lourds (ALU)
            let mut val: u64 = 123456789;
            for i in 0..iterations {
                val = val.wrapping_mul(3).wrapping_add(i);
                val = val.rotate_left(5);
            std::ptr::write_volatile(&mut val as *mut _, val);
        LoadMode::MEM => {
            // Copie mémoire rapide (L1 Cache Stress)
            // Buffer de 4KB (taille d'une page standard)
            const BUF_SIZE: usize = 1024; // 1024 * 4 bytes = 4KB
            let mut buffer = [0u32; BUF_SIZE];
            for i in 0..BUF_SIZE {
                // Écriture volatile pour forcer l'accès RAM/Cache
                std::ptr::write_volatile(&mut buffer[i], i as u32);
        LoadMode::CACHE => {
            // Cache Trashing (Sauts de 64 octets = 1 Cache Line)
            // Force le CPU à recharger les lignes de cache
            const SIZE: usize = 4096;
            let mut arr = [0u8; SIZE];
            let mut idx = 0;
                // Accès avec stride de 64 (Line Size sur x86)
                std::ptr::write_volatile(&mut arr[idx], 1);
                idx = (idx + 64) % SIZE;
        LoadMode::RND => {
            // Branch Prediction Stress (Sauts conditionnels aléatoires)
            let mut val = 0;
                if rand::random() { val += 1; } else { val -= 1; }
// --- GESTION ENTRÉES ---
fn check_inputs() {
    unsafe {
        let kp = |vk| (GetAsyncKeyState(vk) & 1) != 0;
        // [5] LOAD MODE (La nouvelle touche clé)
        if kp(0x35) { STATE_LOAD_MODE = (STATE_LOAD_MODE + 1) % 5; }
        if kp(VK_F1 as i32) { STATE_HZ = if STATE_HZ == 5000 { 10000 } else { 5000 }; }
        if kp(VK_INSERT as i32) { STATE_PHANTOM = !STATE_PHANTOM; }
        if kp(VK_HOME as i32) { STATE_SCRAMBLE = !STATE_SCRAMBLE; }
        if kp(VK_END as i32) { STATE_FENCE = !STATE_FENCE; }
        if kp(VK_B as i32) { STATE_BURST = !STATE_BURST; }
        if kp(VK_M as i32) {
            if !STATE_MMCSS {
                let name = CString::new("Pro Audio").unwrap();
                let mut i = 0;
                let h = AvSetMmThreadCharacteristicsA(name.as_ptr() as *const u8, &mut i);
                if h != 0 { STATE_MMCSS_HANDLE = h; STATE_MMCSS = true; }
            } else {
                AvRevertMmThreadCharacteristics(STATE_MMCSS_HANDLE);
                STATE_MMCSS = false;
// --- MAIN ENGINE ---
fn main() {
    unsafe {
        timeBeginPeriod(1);
        SetPriorityClass(GetCurrentProcess(), REALTIME_PRIORITY_CLASS); // Priorité Processus MAX
        SetThreadPriority(GetCurrentThread(), THREAD_PRIORITY_TIME_CRITICAL); // Priorité Thread MAX
    println!("=====================================================");
    println!("   CS2 OPTIMIZER: V5 ARCHITECT EDITION (INTRINSICS)  ");
    println!(" [5] LOAD MODE : Cycle SSE / RND / MEM / MATH / CACHE");
    println!(" [B] BURST     : CPU Turbo Lock (Micro-Choke)");
    println!(" [M] MMCSS     : Pro Audio Priority");
    let mut last_scramble = get_time_us();
    let mut frame_count = 0u64;
    loop {
        unsafe {
            let start_cycle = _rdtsc(); // Cycle CPU exact au début de la boucle
            // 1. TIMER HARDWARE
            let mut cur: u32 = 0;
            NtSetTimerResolution(STATE_HZ, 1, &mut cur);
            // 2. SCRAMBLE (Affinité dynamique)
            let now_us = get_time_us();
            if STATE_SCRAMBLE && (now_us - last_scramble > 2_000_000) { // 2 sec
                let cores = [2, 4, 6, 8]; // Cœurs pairs (souvent les cœurs physiques P-Cores)
                let idx = (frame_count as usize) % cores.len();
                STATE_CORE = cores[idx];
                let mask = 1 << STATE_CORE;
                SetProcessAffinityMask(GetCurrentProcess(), mask);
                last_scramble = now_us;
            } else if !STATE_SCRAMBLE {
                SetProcessAffinityMask(GetCurrentProcess(), 1 << 1); // Lock Core 1
            // 3. ARCHITECTURAL LOAD (Le cœur de V5)
            // On calcule combien de charge appliquer pour maintenir le CPU éveillé
            // sans voler de temps au jeu.
            if STATE_PHANTOM {
                let current_mode = LoadMode::from_u8(STATE_LOAD_MODE);
                // Intensité variable (LFO simulé par le compteur de frames)
                let intensity = if STATE_BURST { 2000 } else { 500 };
                // Exécute les instructions CPU spécifiques
                run_architectural_load(current_mode, intensity);
            // 4. MEMORY FENCE
            if STATE_FENCE && (frame_count % 4 == 0) {
                 _mm_mfence();
            // 5. SYNCHRONISATION PRÉCISE (Wait Loop)
            // On attend que 0.5ms ou 1ms soit écoulé depuis le début du cycle
            // Utilise _mm_pause() pour ne pas surchauffer pendant l'attente active
            let target_cycles = if STATE_HZ == 5000 { 2_000_000 } else { 4_000_000 }; // Approx cycles
            // (Note: La synchro cycle pure est difficile sans calibration, on utilise un mix)
            // Simule le délai de thread pour laisser respirer Windows
            // NtDelayExecution pour 1 microseconde (le minimum)
            let delay = -10i64; // 100ns units, négatif = relatif. -10 = 1us.
            NtDelayExecution(0, &delay);
            // 6. DASHBOARD V5
            if frame_count % 100 == 0 {
                let mode = LoadMode::from_u8(STATE_LOAD_MODE);
                print!("\r [V5] CORE:{:<2} | MODE:{:<4} | MMC:{} | BST:{} | FNC:{} | TMR:{:.1}ms ",
                    STATE_CORE,
                    mode.as_str(), // SSE, MEM, etc.
                    if STATE_MMCSS { "ON" } else { "--" },
                    if STATE_BURST { "ON" } else { "--" },
                    if STATE_FENCE { "ON" } else { "--" },
                    STATE_HZ as f32 / 10000.0
                io::stdout().flush().unwrap();
        check_inputs();
        frame_count = frame_count.wrapping_add(1);
Posted: 19 Dec 2025, 08:27
by yam1ke
ablemor wrote: ↑
18 Dec 2025, 19:06
Anyone can say this, and in my opinion the code was written by chatgpt, so you don’t really have much intellectual property in it. I don’t think you’re a programmer, but at least you could show 1–2 insights into what does what, what this program actually is, what you manipulate with it, what advantage it gives you over other players. You should also admit that this is not right this way. VirusTotal or any antivirus may not necessarily detect a virus in it, but it can still be malicious. By the way, you could steal anything with it, from a keylogger to pretty much anything.
Oh, I see. Everything is perfectly clear now. ;) My personal advice for you and others like you:
1. Close this topic, forget about its existence.
2. Go back to your wonderful world of registry hacks, BIOS tweaks, and hardware changes.
3. I encourage you to engage ChatGPT as a crucial aid in this endless endeavor.
4. I'm sure on this endlessly fascinating quest for the ultimate input lag fix, you'll eventually find that one magical setting that changes everything.
5. And what stands between you and glory? Hmm, I'd estimate no more than 300 more messages on this very forum. :lol:
Posted: 19 Dec 2025, 08:32
by yam1ke
urikawa wrote: ↑
19 Dec 2025, 08:16
No, it's not me. I'm not a YouTuber or streamer.
All I can say, thay I burn CPU in systematic way, so CPU and Windows processes start to march to my beat in perfect timing with best hit reg you ever had. And after that if you change a little bit this perfect timing, you can get controlled phantom effects in your game.
Posted: 19 Dec 2025, 08:41
by MK92
Lev1n wrote: ↑
19 Dec 2025, 08:13
MK92 wrote: ↑
19 Dec 2025, 07:04
Cool, so after nearly 3 years and 100 posts, you can now delete your account because there is nothing for you here anymore since you found your "fix"...se you in 2-3 days when this magical "fix" won't work anymore...time to change something else in cmd, or bios, or regedit, or download more suspicious files - but keep ignoring the actual culprit, which is network routing or/and electricity.
You do realise that if this would be a Windows problem, then 100 million people would have those problems and not just a few of us, right?
