Acer Predator XR341CK 34" 144Hz Curved Gaming Screen with G-
PoWn3d_0704
Re: Acer Predator XR341CK 34" 144Hz Curved Gaming Screen wit
Post by PoWn3d_0704 » 11 Feb 2015, 20:54
Edmond wrote:Really hard for me to believe they would put TN on this.
But ok, ill agree that there is a small chance as its not said to be IPS.
But most importantly ill do the hardest thing of all - ill just say that i dont know. And neither does anyone else... it might as well be OLED.
I'd like to see this thing be an 8-bit TN.
Just for the sake of cost, if nothing else.
Asus VG248QE with GSync. Blur Busters GSync Contest Winner.
Edmond
Post by Edmond » 12 Feb 2015, 02:33
What you just said... wow... its ... really ignorant.
If you can spend 700$ on a monitor you can also spend 750$. And that would be the absolute MAX cost difference between your 8bit TN and IPS nowadays.
And i dont want the perfect monitor to be spoiled because SOMEONE is buying a monitor they cant afford with their last 700$.
flood
Post by flood » 12 Feb 2015, 03:18
Edmond wrote: If you can spend 700$ on a monitor you can also spend 750$. And that would be the absolute MAX cost difference between your 8bit TN and IPS nowadays.
10/10 would read again
PoWn3d_0704
Post by PoWn3d_0704 » 12 Feb 2015, 20:25
You're sort of cancer dude.
Luckily, whatever I want isnt what Acer will do. They will put in whichever panel THEY want. Pointless to argue about it.
$50 difference? The very first 2440x1440 144hz IPS type display with a Gsync module built in, and it will be $50 more than the TN panel?
Edmond
Post by Edmond » 13 Feb 2015, 02:15
PoWn3d_0704 wrote: You're sort of cancer dude.
I call everyones bullshit and self delusions out... id say im the opposite of cancer, but ok.
PoWn3d_0704 wrote: $50 difference? The very first 2440x1440 144hz IPS type display with a Gsync module built in, and it will be $50 more than the TN panel?
I hear it will cost 800$ or 850$... the ROG Swift cost 800$ @ launch.
flood
Post by flood » 13 Feb 2015, 20:46
Edmond wrote: I hear it will cost 800$ or 850$...
can confirm. i work at acer and we think it's a good idea to upgrade from tn to ips for essentially free. plus it's only 34in
PoWn3d_0704
Post by PoWn3d_0704 » 13 Feb 2015, 22:39
:lol: :lol: :lol:
Edmond
Post by Edmond » 14 Feb 2015, 04:32
:lol: :lol: :lol:
http://www.overclockers.co.uk/showprodu ... &catid=948
Aww, whats that? its cheaper than the swift @ launch?
Dont cry, its ok to be wrong now and again... you are only human scum.
And, yes we were talking about the 27 inch one Flood. Pay attention.
flood
Post by flood » 14 Feb 2015, 05:28
masterotaku
Post by masterotaku » 14 Feb 2015, 05:56
I found it weird that they didn't mention 3D Vision 2 there. Then I read this:
http://www.overclock.net/t/1536499/offi ... t_23444334
:cry:
I hope the 21:9 one will support 3D. It's a game changer for me.
Monitor: Asus PG278QR
