Hmm. This might be a panel-to-panel variance, or a different viewing distance I do (arm's length). My unit does look better when viewing perpendicular. It might be specific to preview units.nimbulan wrote:I found I get the least color distortion if rather than having it perpendicular to my line of vision as you'd expect, I tilt it downwards a little bit. Looking directly on you get some color distortion at the top of the panel (and it gets really bad if you try to use it in portrait mode.)
ROLL CALL: Who uses LightBoost=10%?
Re: ROLL CALL: Who uses LightBoost=10%?
- nimbulan
I suppose that could be. I get a similar effect with all TN panels I've used, but the exact angle it occurs at could vary panel to panel.Chief Blur Buster wrote:Hmm. This might be a panel-to-panel variance, or a different viewing distance I do (arm's length). My unit does look better when viewing perpendicular. It might be specific to preview units.nimbulan wrote:I found I get the least color distortion if rather than having it perpendicular to my line of vision as you'd expect, I tilt it downwards a little bit. Looking directly on you get some color distortion at the top of the panel (and it gets really bad if you try to use it in portrait mode.)
SS4
I turn lightboost on sometimes during gaming on my vg248qe. Otherwise the color looks really bad and its saying a lot from someone who find the color on my vg248qe to be beautiful normally, i wish i could use ULMB instead, but i do appreciate the extra clarity a lot.
- Brama
I have been using lightboost at 10% since I discovered how to enable this function.
I don't like very high brightness and I calibrated the monitor to 80 lux with LB at 10%.
I use it in games, movies, and desktop and I am very satisfied. It seems really to use a CRT.
Mang
I use Lightboost 10%. Haven't even tried the other brightness settings as 10% works great for me and the motion clarity is unbelievable. Circle strafing in CSS is sweet with Lightboost.
- shadman
Convinced another friend of mine to get a new monitor, and he is rocking the Asus VG248QE (had some issues with it at first, all resolved now) and after a few days with it he is using Lightboost 10% 24/7 now. He doesn't seem to think the colors are too washed out (It looked alot better than my other friends BenQ XL2420T (I think that is the one he has)), but only really notices with another display side-by-side to compare.
1peplove1
I am using a BenQ XL2420T and Strobelight by ToastyX @ 10%. Playing battlefield you can literally get the jump on others in fire fights , with strobing on flying a jet you can see things from the cockpit that would otherwise be unseeable. I have tried on/off and different percentages. I adjusted nvidia control panel settings to get the right color, brightness, gamma settings as well. I still feel that 10% is pretty dim and tried playing with 50% and 100% always found myself going back to 10% and finally just settling there and now after a few weeks my eyes have adjusted to the dimness and actually prefer it to higher brightness settings. Took awhile to adjust to the dimness especially during daylight. If I play with higher settings I just dont like the trade off of smoothness to what little brightness you get.
gib
I also used lightboost at 10% until installing the gsync mod a few days ago.
I do miss that flexibility to adjust on the fly. I'm sure over time I'd get used to ULMB being at this fixed rate, but with this kind of tech, who doesn't like having a choice?
- sharknice
Yeah same for me, but the hardware button on the monitor is really nice though. I blew some minds at a LAN this weekend using testufo moving map and switching ULMB on and off with the button.gib wrote:I also used lightboost at 10% until installing the gsync mod a few days ago.
SS4
Anyone else gets a nvidia kernel crash when strobelight is running for too long?
Sometimes im gaming without lightboost but with the strobelight exe running and game crashes because of nvidia kernell . . .
