Re: any chances to get crt motion quality at 60hz in the fut
Posted: 27 Mar 2014, 10:18
CRT monitors have always behaved like CRT TVs when they both run at the same refresh rate.Blurless wrote:Does that apply to 30fps video as well? Do blurays and youtube videos on a crt monitor all have a double image effect? If that is the case the big transistion to lcd monitors makes a lot more sense. Or is there a way to make crt monitors more like crt tv's?
Yes, 30fps@60Hz always has a double image effect on CRT and plasma, whether it's video or games.
framerate at half Hz on impulsed/strobed displays = double image effect
framerate at third Hz on impulsed/strobed displays = triple image effect
framerate at quarter Hz on impulsed/strobed displays = quad image effect
This is simply because your eyes are continually moving between all the repeat refreshes. As you track moving eyes on moving objects on a screen, your eyes are in a different position during the next refresh cycle. So the repeat refresh will appear at different positions in the eye. So that's why you see a double-edge effect during 30fps@60Hz impulsed (CRT) or during 60fps@120Hz impulsed (LightBoost or CRT), as examples.
-- Example: View http://www.testufo.com on a CRT or LightBoost to understand the "multi image effect".
It also happens during PWM dimming (rapid-flashing method of brightness dimming -- e.g. adjust certain LED-backlit LCD to 0% brightness while viewing http://www.testufo.com), e.g. 60fps@180Hz PWM dimming = triple image effect.
-- Continuously-shining (flickerfree) displays don't show multi image effects, they just show more motion blur during longer same-frame visibility times (e.g. Lower framerates at http://www.testufo.com just simply has more motion blur. View on a PWM-free LCD, or at 100% brightness).
