Page 4 of 4
Re: Alienware AW2518H
Posted: 20 Mar 2018, 09:59
by hux0
Really good question. It actually reminds me very, very much of faulty GPU Ram. This often provides a similar checkerboard flashing. But this can't be the reason here. I tried two GPU, both show the same problem.
That youtube guy meanwhile responded, but seems nothing that helps. He is telling us it is an overclocked 144Hz Panel, and he is leaning towards "power problems" would create those issues.
The funny thing is that the behaviour won't change with GSync on or off; 60/120/240 Hz; run as a single monitor or paired with another screen and an Oculus Rift. This really looks to be a technical problem Dell needs to fix. At least it seems not very common so there is a high chance to RMA for a flawless model.
It's really annoying how many problems many of those high refresh rate screens have, and how bad the quality control nowadays is.
Posted: 20 Mar 2018, 11:54
by A Solid lad
^Exactly...
Earlier I paid less attention to people on this forum claiming that 240hz screens were half-baked... but seeing and experiencing how hard it is to get one that works properly, makes me give them credit.
Posted: 20 Mar 2018, 16:31
by vladislavmedvednikov
I bought mine 9 days ago and my unit is free of this problem.
Posted: 22 Mar 2018, 05:42
by hux0
So I have received a reply from Dell this morning. I had sent a video along with my Support Ticket, and the guy on the phone reviewed it. He put me on hold for 2-3 minutes. He talked to a lvl 2 Tech, and that guy advised this issue should be a failure between the Panel and the Converter Board. An exchange unit is on the way to me now.
Quick service, I hope the exchange unit is a flawless one.
Posted: 22 Mar 2018, 07:13
by A Solid lad
hux0 wrote:So I have received a reply from Dell this morning. I had sent a video along with my Support Ticket, and the guy on the phone reviewed it. He put me on hold for 2-3 minutes. He talked to a lvl 2 Tech, and that guy advised this issue should be a failure between the Panel and the Converter Board. An exchange unit is on the way to me now.
You received some nice treatment there, happy for u!
Where do u live btw?
Posted: 22 Mar 2018, 09:17
by hux0
Germany. I have had bad experiences with the Dell Hotline in the past, but this was a good one.
Posted: 29 Mar 2018, 13:42
by A Solid lad
Some more relevant stuff about this monitor:
https://youtu.be/9VbVWY1-FPc
Posted: 14 Aug 2018, 21:31
by a_Criminai
hux0 wrote:Hey guys. I got this Alienware screen today. Unboxed and plugged it in. But there is a huge problem which I can't seem to solve yet. I Google for it and found a guy on YouTube that has the same issue, but no solution. Is that a hardware fault, or what could cause this issue?
Link to the video:
https://m.youtube.com/watch?v=3oci3XJcMU8
Would appreciate to receive some help. Hopefully there is a fix so I don't have to rma this one.
I had this issue on the Viewsonic XG2530 which uses the same panel. I discovered that it was a Gamma problem. Setting the Gamma to 2.0 removed the issue completely whereas it was a problem when set to 2.2 or 2.4.
