edit
Notty_PT
Re: Asus XG248Q 240hz - Got one! My impressions
Post by Notty_PT » 21 Dec 2018, 01:47
pox02 wrote:The xg248q overdrive implementation are very inconsistent compre to aw2518hf so i dont know where you come with idea that xg248q faster then aw2518hf
Maybe that depends on the samples and we had different luck. My alienware struggles hard on bright colours while xg248q doesnt. It is way faster. Same with input lag.
Now I hope you are not using anything higher than Level 3 Overdrive on the Asus. At least on my unit it gets bad after Level 3 (purple trail on grey/dark colours) and obvious overshoot.
Kiryakov
Post by Kiryakov » 21 Dec 2018, 04:50
Chief Blur Buster wrote:DisplayPort cable issues can sometimes do that, but we need to verify if it's a monitor issue or cable issue.
Try keeping DisplayPort wires away from your power supply & away from power bars & away from power wires / outlets (by at least several inches where possible). See if that helps to an extent. High Hz with high bandwidth is very sensitive to issues. However, it could be a monitor defect as well since you had an XL2546. You may want to try one cycle of RMA to see if this solves the problem, e.g. a monitor that is more sensitive to disruptions than average especially when warmed up.
Problem resolved! My graphic card ASUS RX480 have a problem with monitor only on 240Hz. I try with another graphic card - R9 270X, no have a flicker-flashing issue.
Post by Chief Blur Buster » 21 Dec 2018, 13:24
It can also be a defective graphics card (bad output jack). All the newer cards should be able to do 240Hz fine.
pox02
Post by pox02 » 25 Dec 2018, 03:26
Can someone try ELMB + Adaptive Sync and tell me how its feels the input lag will be higher i think ? Not sure im not home so i cant test it
Notty_PT
Post by Notty_PT » 31 Dec 2018, 06:20
So, I got this monitor for 339€ and right now it is at 475€ in my country again! I checked amazon de, fr, es, uk, and same. 450€+ plus. What happened? I start to think I made a great deal!
Post by Chief Blur Buster » 31 Dec 2018, 13:43
pox02 wrote:Can someone try ELMB + Adaptive Sync
Can't be used at the same time, but you can test one or the other.
Notty_PT wrote:So, I got this monitor for 339€ and right now it is at 475€ in my country again! I checked amazon de, fr, es, uk, and same. 450€+ plus. What happened? I start to think I made a great deal!
Yes, that's indeed a great deal. Good catch!
Reflex
Post by Reflex » 14 Feb 2019, 16:46
Uhm, hello. Hooe someone will answer me. So my xg248q just arrived, i connected it to my gtx 1080 with the dp cable that has come with it. initially the monitor was set to 60hz so i went to nvidia control panel but the highest option is 120hz. Why is this? When the pc is off and the monitor on it says “ no display port cable detected” is it normal? I’ve already tried plugging/unplugging the dp cable but no luck... help pls, sry for my bad english
Notty_PT
Post by Notty_PT » 14 Feb 2019, 17:02
Reflex wrote:Uhm, hello. Hooe someone will answer me. So my xg248q just arrived, i connected it to my gtx 1080 with the dp cable that has come with it. initially the monitor was set to 60hz so i went to nvidia control panel but the highest option is 120hz. Why is this? When the pc is off and the monitor on it says “ no display port cable detected” is it normal? I’ve already tried plugging/unplugging the dp cable but no luck... help pls, sry for my bad english
Hi! On nvidia control panel scroll down on the resolutions until you see "PC" and choose 1080p 240hz there, not on "Ultra HD, HD" that appears at the top.
