PresentMon: measure both frame throughput (fps) and latency
Digika
Re: PresentMon: measure both frame throughput (fps) and latency
Post by Digika » 27 Oct 2020, 19:30
Hey, can someone help me to correlate PresentMon terminology with MS one?
PresentMon describes them as following:
Hardware: Legacy Flip
Indicates the app took ownership of the screen, and is swapping the displayed surface every frame.
Hardware: Legacy Copy to front buffer
Indicates the app took ownership of the screen, and is copying new contents to an already-on-screen surface every frame.
Hardware: Independent Flip
Indicates the app does not have ownership of the screen, but is still swapping the displayed surface every frame.
Composed: Flip
Indicates the app is windowed, is using "flip model" swapchains, and is sharing its surfaces with DWM to be composed.
Hardware Composed: Independent Flip
Indicates the app is using "flip model" swapchains, and has been granted a hardware overlay plane.
Composed: Copy with GPU GDI
Indicates the app is windowed, and is copying contents into a surface that's shared with GDI.
Composed: Copy with CPU GDI
Indicates the app is windowed, and is copying contents into a dedicated DirectX window surface. GDI contents are stored separately, and are composed together with DX contents by the DWM.
MS DX docs terminology:
https://docs.microsoft.com/en-us/window ... wap_effect
and
https://youtu.be/E3wTajGZOsA
From my understanding so far:
Hardware: Legacy Flip - Fullscreen Flip or so called true FullScreen Exclusive
Hardware: Legacy Copy to front buffer - Fullscreen BitBlt
Composed: Copy with CPU GDI - worst-case scenario described by Jesse in fullscreen - Fullscreen Proxy
Really curious what Composed: Copy with GPU GDI is tho.
mirh
Post by mirh » 30 Dec 2022, 13:56
Digika wrote:
27 Oct 2020, 19:30
That would happen with just about anything "old" not using the flip model (unless they are using exclusive fullscreen that is of course).
Source code also mentions this should correspond to "Win7 Blit" (which in turn was supposedly an improvement over CPU-only Vista).
https://learn.microsoft.com/en-us/windo ... -resources
Fun fact: until 526.47 there was no other mode Optimus gpus could use for non-native apis (since DWM expects dx surfaces AFAIU).
Instead since DXGI swapchain presentation landed windowed is always upgraded to Composed: Flip, while fullscreen (which AFAICT had never been truly achievable in these conditions) is always a very decent Hardware: Independent Flip.
afn7
Post by afn7 » 04 Jan 2023, 09:48
Heres my results:
Borderless: Image
Full Screen: Image
Without game: Image
And this is the problem I'm facing all the time. This is replay but I saw hitting the car when its live.
https://streamable.com/w8qu8z
Asus Rog Strix z590 Gaming E
Intel I7 11700k
Corsair Vengeance lpx 32gb 3600mhz cl16
Msi RTX 3060 TI Ventus 3x OC
CM Power supply 750w 80+ Bronze
sherifmagdy32
Post by sherifmagdy32 » 04 Jan 2023, 19:17
Is this good or bad :ugeek:
evmadic
Post by evmadic » 28 Sep 2023, 17:35
Sorry for the newbie question but I can't figure out how to draw 1% and .1% FPS lows in intel presentmon. There's no option for it in the loadout configuration so I'm guessing it must be somewhere in a subcategory
5800x3d, RTX 4070 ti, Acer Nitro XV252QF 390Hz
https://www.twitch.tv/evmadic
