Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
Anonymous768119
Re: Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
Post by Anonymous768119 » 11 Jun 2020, 18:22
Slightly lower than mine. Do you play cs:go and experience some weird stuff like inconsistent mouse movement and bad hitreg?
Shyzo
Post by Shyzo » 11 Jun 2020, 19:50
No i dont play csgo. But on monday i will have intel i5 9400f to test here. so ill see if there will be changes :)
btw what is hitreg?
deama
Post by deama » 13 Jun 2020, 15:15
Here's what I get:
I've got a ryzen 5 3600, tridentz dual channel ram sticks at 3200mhz @ 16,18,18,38,56
Running on X570 gaming x mobo and a 2060 super; I also disabled turbo and just locked the CPU speed at 4.1GHz, if that matters.
Kinda disappointed by these timings, but my system does feel more responsive than my previous computer (I built this one back in march).
My old system had an i5 4690k, 970gtx, z97 PC mate mobo, and I don't fully remember the ram timings or even mhz, I think the mhz was 1666mhz or so.
1000WATT
Post by 1000WATT » 13 Jun 2020, 16:51
Brainlet wrote: ↑
10 Jun 2020, 12:11
Yes, RAM affects mouse input a lot.
Stress tests generally don't seem to detect error correction which can lead to really bad mouse input. For starters I suggest ditching AIDA as the main "on paper" benchmark tool and using https://software.intel.com/content/www/ ... ecker.html instead.
What will change ? With the next test, can we see errors in memory that affect mouse input?
1000WATT
Post by 1000WATT » 13 Jun 2020, 17:04
schizobeyondpills wrote: ↑
09 Jun 2020, 13:53
arguments for RAM latency nanoseconds being useless
- people in this thread dont feel it on their unoptimized setups
You understand that this is a vicious circle. ?
1000WATT
Post by 1000WATT » 13 Jun 2020, 17:16
What is the point of offering memory testing with a test for servers, with avx instructions?
Maybe we will immediately show and say that it is intel.
Most people will not be able to understand why such a difference.
ptuga
Post by ptuga » 13 Jun 2020, 18:22
1000WATT wrote: ↑
13 Jun 2020, 17:16
System specs? I can't get it nowhere near that on my Intel + b-die system.
schizobeyondpills
Post by schizobeyondpills » 13 Jun 2020, 19:34
1000WATT wrote: ↑
13 Jun 2020, 17:16
>hiding command line params and using lowest settings
must hurt to lag
1000WATT
Post by 1000WATT » 13 Jun 2020, 19:46
ptuga wrote: ↑
13 Jun 2020, 18:22
1000WATT wrote: ↑
13 Jun 2020, 17:16
Perfect :lol:
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 13 Jun 2020, 20:17
