Got it ! Thank you for the clarification.. I did it successfully now. Couple side notes is, I did indeed reset it to default and examined it was reset properly. When I went back to do the add thing, it actually did NOT work when I did as you just said and deleted nothing. (as nothing seemed to change after restarting in the Nvidia CP list)RLCScontender wrote: ↑17 Jun 2020, 16:42The upper (very top) add" button is the one u click on to input the 240.000 resolution
But it did work when I deleted ONLY the ones in that top box (Detailed Resolutions) and then added the 240hz there. Once restarting it looks exactly as your guys' windows looks now. I have the entire list still, BUT only PC 1920x1080 @240hz is marked as "NATIVE". None other say "Native" besides them. Is this correct ?
The first instructions from a while ago do say to delete things.. just not descriptive where and thats what led me to the initial prob. So again, you do need to "delete all" in the default list of that top box "Detailed Resolutions" BEFORE you then "Add" the one.
The second oddity is (not like it matters but) - using CPU restart glitches out my PC. Im on 64bit too, so I choose that one. It works, and everything appears fine except it make it so my start menu won't appear. I have to restart it the real way then everything comes back.
To verify this I did the whole process a few times and it certainly is CPU issue. The solution is to not use its restart and just manually restart as you normally would (start menu, power, restart). This also causes the GPU setting to then properly take effect.
Just wanted to let everyone know in case someone new (like me) was looking for answers like this.
