Your Inspector version seems to be outdated. Try getting the latest one from here : https://github.com/Orbmu2k/nvidiaProfil ... r/releasesmckayvz wrote: ↑09 Aug 2020, 10:02Hey I followed op instructions and I got this error popping up every time I try to import a profile. I'm using a laptop (Dell ins 7567). May I have your screenshots of NI for the Riot LLHP profile so I can try to do it manually?
Some profile(s) could not imported error: https://imgur.com/TJTFCsh
Reducing Input Delay with Nvidia Inspector
- MaxTendency
Re: Reducing Input Delay with Nvidia Inspector
mckayvz
Oh it worked, tkx. I saw it said pre-release so I thought it was BETA build hahaMaxTendency wrote: ↑09 Aug 2020, 13:48Your Inspector version seems to be outdated. Try getting the latest one from here : https://github.com/Orbmu2k/nvidiaProfil ... r/releasesmckayvz wrote: ↑09 Aug 2020, 10:02Hey I followed op instructions and I got this error popping up every time I try to import a profile. I'm using a laptop (Dell ins 7567). May I have your screenshots of NI for the Riot LLHP profile so I can try to do it manually?
tosh
i used the Riot Low_Latency_High_Performance v2 config , is it normal that it changed my settings in nvidia manage 3d settings. it turned off low latency mode for example surely thats bad
- MaxTendency
Yes thats normal, inspector and nvidia control panel are just GUI , they simple make changes to the driver settings.
That however is not normal. Probably some bug/import error. Set it to Ultra manually, you can also try On.
I have updated OP with some more information about some specific settings from Melody's site. viewtopic.php?f=10&t=7323#p55433
TN_fun
I used Low_Latency_High_Performance v2 config and it made my GPU clock to max after reboot. Does not reset at idle. It is not normal. I returned the default settings.
Conan
Ty man. Ill check it out!MaxTendency wrote: ↑16 Aug 2020, 05:24I have updated OP with some more information about some specific settings from Melody's site. viewtopic.php?f=10&t=7323#p55433
csplayer
It has seemingly increased my FPS a lot.MaxTendency wrote: ↑03 Aug 2020, 13:15Yes create a DWORD, and then restart pc. You should lose a mesureable amount of fps (4-5% for me) but input should feel snappier. You can then delete the key if you want to revert back.
I notice this mostly in busy deathmatch servers my lowest fps has improved with about 50 frames.
Also i made a fps benchmark using the fps benchmark map in CS:GO.
Before ( No registry key for DisableWriteCombining ): https://imgur.com/3kavZsA
After DDS on 1: https://imgur.com/jJQgB7j
- BTRY B 529th FA BN
Simon95
I cant find these settings in my profilenvidiainspector. How can i unlock this settings?Buffers
What to expect when changing all these values: The lower, the better input and the worse fps. The higher, the better fps and the worse input.
OGL_PULL_MEM_BUFFER_SHARED_THRESHOLD - This controls a dynamic threshold by setting a value to which the memory pull buffer "moves". Not adviced to set this below 0x00000080.
OGL_PULL_MEM_DEFAULT_BUFFER_SIZE - Default memory pull buffer size (starting value). Not adviced to set this below 0x00000080.
MCFORCEHOSTSTAGINGBUFFERSIZE - Sets the Host Staging Buffer Size. This is a global buffer that changes pretty much everything in the GPU queue. Not adviced to set this below 0x00000020.
MAX_PENDING_CMD_BUFFERS - Sets the max pending command buffers that are allowed at the same time. Not adviced to set this below 0x00000001.
ffs_
Make sure you're using proper Nvidia Profile Inspector: https://github.com/Orbmu2k/nvidiaProfil ... g/2.3.0.12
