HUGE Fix at Input Lag!!!!
- BTRY B 529th FA BN
Re: HUGE Fix at Input Lag!!!!
howiec
howiec
Not necessarily as that depends on what you need to adjust. If you are able to access all parameters you need, then there's basically no difference (also assuming no relevant bugs). I haven't tested/compared it's different features though.BTRY B 529th FA BN wrote: ↑23 Nov 2020, 23:00Is it bad?howiec wrote: ↑23 Nov 2020, 22:33Because it's a fork:
https://github.com/DeadManWalkingTO/NVi ... spectorDmW
Ancharizz
Hey,pox02 wrote: ↑15 Nov 2020, 20:42if u want really low input lag for overwatch try my settings
why set refresh rate to ff0? its hidden feature that nvidia missing its called low-Latency REFRESH_RATE_OVERRIDE_LOW_LATENCY_RR_MASK
u can check here https://docs.nvidia.com/gameworks/conte ... gs_8h.html
DISALLOWED is the lowest input lag flip is good to but if u want hit ur shots over smoothing try it
now the real settings that give u snappy mouse movement
MAX_PENDING_CMD_BUFFERS to 0x1 remove the stutters/lag
MCFORCEHOSTSTAGINGBUFFERSIZE this is really fun u can check it over 1000 but recommending not go above 20 set it 0x00000001 for extreme mouse input lagless
enjoy the fastest mouse input in ow
one more thing i forgot to say to u make sure low latency is off cause disallowed work best with off
idk if someone already answered, but im kinda lost rn: How can you use these settings?
thank you for answers <3
Regards,
Ancharizz
- jorimt
FYI, I've moved the somewhat off-topic posts involving FSO vs. exclusive fullscreen to it's own thread here:
viewtopic.php?f=10&t=7818
Unreazz
The only HUGE input LAG fix which i know and worked once for me is the "200 series Intel Chipset pastebin" fix. just google it and give it a try. i did and it worked for me. everything was more responsivly and faster but since i had to take a clean install on my pc, its not working anymore for me but when it worked, i guarantee you it was definitly not a placebo
Unixko
power of placebo is to strongUnreazz wrote: ↑26 Nov 2020, 05:11The only HUGE input LAG fix which i know and worked once for me is the "200 series Intel Chipset pastebin" fix. just google it and give it a try. i did and it worked for me. everything was more responsivly and faster but since i had to take a clean install on my pc, its not working anymore for me but when it worked, i guarantee you it was definitly not a placebo
chenifa
ffs_
