Page 4 of 8
Re: HUGE Fix at Input Lag!!!!
Posted: 23 Nov 2020, 21:37
by BTRY B 529th FA BN
Posted: 23 Nov 2020, 22:33
by howiec
BTRY B 529th FA BN wrote: ↑
23 Nov 2020, 21:37
Why do I have NVIDIA Profile Inspector DmW 3.50, ?
Because it's a fork:
https://github.com/DeadManWalkingTO/NVi ... spectorDmW
Posted: 23 Nov 2020, 23:00
Posted: 23 Nov 2020, 23:23
by howiec
23 Nov 2020, 23:00
howiec wrote: ↑
23 Nov 2020, 22:33
23 Nov 2020, 21:37
Is it bad?
Not necessarily as that depends on what you need to adjust. If you are able to access all parameters you need, then there's basically no difference (also assuming no relevant bugs). I haven't tested/compared it's different features though.
Posted: 24 Nov 2020, 12:55
by Ancharizz
pox02 wrote: ↑
15 Nov 2020, 20:42
if u want really low input lag for overwatch try my settings :)
why set refresh rate to ff0? its hidden feature that nvidia missing its called low-Latency REFRESH_RATE_OVERRIDE_LOW_LATENCY_RR_MASK
u can check here https://docs.nvidia.com/gameworks/conte ... gs_8h.html
DISALLOWED is the lowest input lag flip is good to but if u want hit ur shots over smoothing try it
now the real settings that give u snappy mouse movement
MAX_PENDING_CMD_BUFFERS to 0x1 remove the stutters/lag
MCFORCEHOSTSTAGINGBUFFERSIZE this is really fun u can check it over 1000 but recommending not go above 20 set it 0x00000001 for extreme mouse input lagless
enjoy the fastest mouse input in ow :)
one more thing i forgot to say to u make sure low latency is off cause disallowed work best with off
Hey,
idk if someone already answered, but im kinda lost rn: How can you use these settings? :?:
thank you for answers <3
Regards,
Ancharizz
Posted: 24 Nov 2020, 16:46
by jorimt
FYI, I've moved the somewhat off-topic posts involving FSO vs. exclusive fullscreen to it's own thread here:
viewtopic.php?f=10&t=7818
Posted: 26 Nov 2020, 05:11
by Unreazz
The only HUGE input LAG fix which i know and worked once for me is the "200 series Intel Chipset pastebin" fix. just google it and give it a try. i did and it worked for me. everything was more responsivly and faster but since i had to take a clean install on my pc, its not working anymore for me but when it worked, i guarantee you it was definitly not a placebo
Posted: 26 Nov 2020, 05:44
by Unixko
Unreazz wrote: ↑
26 Nov 2020, 05:11
power of placebo is to strong
Posted: 26 Nov 2020, 10:02
by chenifa
pox02 wrote: ↑
15 Nov 2020, 20:42
Hey, which setting are you talking about here?
Posted: 26 Nov 2020, 11:40
by ffs_
chenifa wrote: ↑
26 Nov 2020, 10:02
2 - Sync And Referesh
Frame Rate Limiter: 0x00200000 PS_FRAMERATE_LIMITER_DISALLOWED
Frame Rate Limiter Mode: Limiter V2 - Force Off [Enables Limiter V1 (Less Input Lag)]
Should be used together.
