FPS drop/microstutter debugging after replacing 95% of the PC and multiple re-installs
wittycoder
Re: FPS drop/microstutter debugging after replacing 95% of the PC and multiple re-installs
Post by wittycoder » 02 Dec 2021, 19:20
I just got the last of my thermal pads today, so I'll be pasting/padding soon to try that out.
2kMonitor
Post by 2kMonitor » 07 Dec 2022, 11:57
Have you found a solution? My roommate and I are experiencing the same problem. I feel like it has to do with the electricity considering both PCs are experiencing the same frequent micro stuttering and no amount of replacing parts seems to work.
wittycoder
Post by wittycoder » 08 Dec 2022, 00:24
I replaced AMD CPU and mobo with Intel and the problem is fixed. All other components are the same, not sure where the issue is, but it has something to do with AMD chipset or CPU, and no updates or settings I tried resolved the issue.
MegaMelmek
Post by MegaMelmek » 08 Dec 2022, 03:08
what kind cpu and mobo you get?
assombrosso
Post by assombrosso » 08 Dec 2022, 09:17
wittycoder wrote:
08 Dec 2022, 00:24
It will be back soon bro
wittycoder
Post by wittycoder » 08 Dec 2022, 13:10
assombrosso wrote:
08 Dec 2022, 09:17
It's already been 11 months, I don't think so!
MegaMelmek wrote:
08 Dec 2022, 03:08
12900k CPU and Asus ROG Strix Z690 D4 mobo (DDR4 so I could use the same RAM)
Vocaleyes
Post by Vocaleyes » 08 Dec 2022, 13:17
What windows version? E.g. 22h2 or w/e
wittycoder
Post by wittycoder » 08 Dec 2022, 13:20
Vocaleyes wrote:
08 Dec 2022, 13:17
21H2 right now, I had some issues after updating to 22h2 (not gaming related - software developer tool related) and I rolled back. Gaming was fine and not stuttering on either version of Win 11.
Vocaleyes
Post by Vocaleyes » 08 Dec 2022, 13:55
Understood, thanks for the info!
assombrosso
Post by assombrosso » 09 Dec 2022, 23:25
wittycoder wrote:
08 Dec 2022, 00:24
Can you explain the problem you had with amd in fine detail ?
