Page 4 of 4
Re: [Troubleshooting Equipment] ways to mitigate interference
Posted: 02 Oct 2021, 04:16
by nick4567
Magnus opus part 1
ground loops and their potential to cause interference as well as act as a very very strong antenna for interference, there are 2 types of ground when you are talking about a pc system the home/safety ground aswell as the ground to the pc case (ex psu is grounded to pc case by screw as well as motherboard and hdd) effectively the difference in voltage potential of the reference ground for a circuit which shares multiple grounding paths is what creates a ground loop; solution the single point ground i will explain in this post how to effectively single point ground both the pc and ur home this would eliminate a huge antenna that picks up all the emi and rf and make all of ur issues significantly better.
Single point ground the pc, this is relatively straight forward all you need is some nylon screws and electrical tape (for the i/o plate) you are gonna want to replace all metal standoffs but one with nylon standoffs for the motherboard generally the best place to keep ur metal standoff would be by the 24 pin connector (wire that powers the motherboard) and replace all but one metal screws for the psu to pc case
Single point ground home ground is much more difficult and will require a really good electrician, basically u r going to need to ground ur home using only one path connected to one point at the bar, example ur home ground is connected to water pipes as well as gas pipes and possibly steel bars as well as a rod, if all of these are done using a different wire connected to multiple points at the grounding bar then a loop can form.
Some links if u want to deep dive more into the theory
https://www.csemag.com/articles/groundi ... -or-multi/
http://www.industrial-electronics.com/DAQ/sss_5-0.html
Posted: 11 Nov 2021, 15:47
by Slender
nick4567 wrote: ↑02 Oct 2021, 04:16
Magnus opus part 1
I understand correctly, I change all the screws on the motherboard, except 1, and on the power supply and leave 1 of 4
Posted: 15 Nov 2021, 10:49
by Mugabi
Slender wrote: ↑11 Nov 2021, 15:47
Magnus opus part 1
u feel any change?
Posted: 15 Nov 2021, 14:30
by nick4567
Magnus opus part 1
yes, but not the screws the standoffs i made a mistake in the post
Posted: 15 Nov 2021, 14:41
by nick4567
in terms of mitigating the susceptibility of your pc componenets to radiated noise you are going to want to shield it via a case that is secc standard (secc is a commercial standard all steel case so it is slightly more expensive than a normal case secc can absorb both rf fields as well as magnetic fields) there is no windows on these cases they r relatively ugly but they will at the very least possibly improve your experience if you are (especially if you are dealing with radiated noise), one more thing i would advise is to possibly get in contact with ham radio operators if they are near by with testing equipment and attempt to test the noise floor of your location should it exceed a certain threshhold the regulatory body of your country would get involved (regulatory bodies love to sue big companies)
Posted: 15 Nov 2021, 17:29
by Slender
Mugabi wrote: ↑15 Nov 2021, 10:49
Magnus opus part 1
u feel any change?
I haven't tried it yet, to be honest I have no idea where to start..
Posted: 15 Nov 2021, 20:22
by nick4567
Slender wrote: ↑15 Nov 2021, 17:29
Magnus opus part 1
u feel any change?
you unscrew your motherboard you then take it out and replace all standoffs but one with nylon standoffs u r gonna want to look up ur case online to get the correct size standoffs really not that complicated
