Bad mousetester graph when videocard is on
Re: Bad mousetester graph when videocard is on
Post by Slender » 15 Nov 2021, 17:27
slaver01 wrote: ↑
15 Nov 2021, 04:03
My graph with dual boot w7/w10
same on 7
slaver01
Post by slaver01 » 16 Nov 2021, 05:49
I don't know what to use to play (fortnite).
w10 i have more fps than w7. Should I look more at the graph or at the fps?
W10 21h1: driver 471.96
- Max 719 fps
- 1% 91 fps
- 0.1% 39 fps
W7 sp1: driver 471.96
- Max 625 fps
- 1% 89 fps
- 0.1% 37.5 fps
Post by Slender » 16 Nov 2021, 15:25
slaver01 wrote: ↑
16 Nov 2021, 05:49
- Max 719 fps
- 1% 91 fps
- 0.1% 39 fps
- Max 625 fps
- 1% 89 fps
- 0.1% 37.5 fps
if fortnite use dx11, w10 better.
try 8.1
Post by Slender » 16 Nov 2021, 15:26
i try to CLRTC, maybe it work, see later
slaver01
Post by slaver01 » 17 Nov 2021, 02:40
Slender wrote: ↑
16 Nov 2021, 15:26
what is CLRTC?
Post by Slender » 18 Nov 2021, 16:21
it is like factory reset bios with memory cache, but it not work in my case. same problem..
2 variants:
1) motherboard
2) emi, ha-ha
slaver01
Post by slaver01 » 19 Nov 2021, 10:03
Slender wrote: ↑
18 Nov 2021, 16:21
2 variants:
1) motherboard
2) emi, ha-ha
I never got a graph like that (as in your last photo) with windows 10
Post by Slender » 19 Nov 2021, 10:46
slaver01 wrote: ↑
19 Nov 2021, 10:03
Slender wrote: ↑
18 Nov 2021, 16:21
2 variants:
1) motherboard
2) emi, ha-ha
im use last revios, 0.5ms timer with 1 core affinity on my pci-e usb 2.0 card and useplatformtick no
celomu
Post by celomu » 01 Sep 2025, 15:01
Hello!
Well, is there any news?
I also encountered this problem!
I noticed when music is playing (via an external DAC) this problem occurs more often!
I blame not only the OS but also the chipset!
(I've been suffering for 3 days already, looking for the root of the problem.
and in general I've been suffering for more than 5 years, I'm extremely sensitive to frame drops and sound quality... and where people will say it plays normally, the picture is normal, the song sounds good, I'll say... something's not right here!))
Post by Slender » 01 Sep 2025, 22:52
celomu wrote: ↑
01 Sep 2025, 15:01
Hello!
i think it dwm.
anyway, im not fix that.
move gpu and usb controller to different cores may little bit fix it.
also try play with interrupt steering.
