BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
vigilanteee
Post by vigilanteee » 08 Sep 2020, 11:31
I think doing all this stuff might have either bugged my monitor out a bit and/or it leaves traces behind at OS/nvidia driver level and bugs things out.
Now fullscreen exclusive mode doesn't work for me a lot of times even in 144hz and with all the 200hz stuff disabled. It gives me the no signal message on my monitor and then i have to press alt + enter to put it in window mode and then driver crashes.
benq x2411z running on dvi on windows 10 1809.
chumacher
Post by chumacher » 10 Sep 2020, 18:33
My Benq XL2420z is stable @ 223hz.
240hz works but white screen manifests sooner or later.
250hz works also but blackscreen occurs after using minute or two..
OceanLerp
Post by OceanLerp » 14 Sep 2020, 22:00
I can confirm as of now this method does not work on the XL2731, when I try I can only make the Out of range! Disappear. When I try Display application - 0xDC it doesn’t make the desktop appear :(
r3drum38
Post by r3drum38 » 15 Sep 2020, 06:39
Hello guys (and chief),
I proudly got a XL2720Z (V3) at a low price 3 years ago, and glad to see that i can achieve 220Hz with blur reduction on.
For guys who are interested, i play Valorant at 220hz with strobe backlight at 220hz and it's almost cristalclear.
In my case, i tried to put the little exe made by another member but my antivirus just delete it at every startup.
So i use the game-switch at every start.
For my information, is that possible to create a mod /soft that put the pixel refresh of the screen at 220hz speed (4.5ms, backlight OFF) and a "pause" of scanning of 2.5ms (backlight ON), in order to get a full 144hz no crosstalk screen ?
And for the future : Why no screen builder use scanning backlight instead of blinking ? that should make REALLY like CRT screen ?
r3d
Post by RealNC » 15 Sep 2020, 07:36
r3drum38 wrote: ↑
15 Sep 2020, 06:39
Because for that you need a backlight with a much higher brightness, which is expensive.
r3drum38
Post by r3drum38 » 15 Sep 2020, 09:02
RealNC wrote: ↑
15 Sep 2020, 07:36
r3drum38 wrote: ↑
15 Sep 2020, 06:39
It's the deal, you give up some nits to get a lot of clear motion. Like on the Strobe Utility.
I'm quite sure that 2 zones are totally enough to remove completely every visible crosstalk.
Albotino
Post by Albotino » 17 Sep 2020, 06:34
Hello guys...im using the benq xl2420t 120hz...is it possible to overclock?
does anyone has it?
Edit: im asking because benq xl 2420t have 2 model 120hz and 144hz...and i have the oldest 120hz.
So...is it possible to oc it at 144hz or 165hz without lower my resolution?
https://t.me/pump_upp
Albotino
Post by Albotino » 23 Sep 2020, 06:18
i downloaded the oorbuster but i cant find the oorbuster.exe
anyone pls help!!
Post by RealNC » 23 Sep 2020, 08:20
Albotino wrote: ↑
23 Sep 2020, 06:18
anyone pls help!!
You probably downloaded the source code, not the exe. Go to the "Releases" page (link is below the "About" section, in the right side of the page.)
MarkBurghouwt123
Post by MarkBurghouwt123 » 25 Sep 2020, 06:39
Can someone explain why it doesn’t work kn my monitor? I have the XL2411P and it wont go over 150 hz with the OORBUSTER method. When I go over it shows a really artifacted image for half a second and then proceeds to show out of range. What am I doing wrong?
