Presenting the ZOWIE XL2540 240Hz
ecay
Re: Presenting the ZOWIE XL2540 240Hz
Hi guys. I cant find how to access XL2540 service menu and activate blur reduction. Please help me thank you.
The factory menu instructions are here.ecay wrote:Hi guys. I cant find how to access XL2540 service menu and activate blur reduction. Please help me thank you.
The instructions work for the following monitors:
BenQ ZOWIE XL2540 - 24.5" 1920x1080 TN 240Hz FreeSync
BenQ ZOWIE XL2546 - 24.5" 1920x1080 TN 240Hz FreeSync
BenQ ZOWIE XL2720 - 27" 1920x1080 TN 144Hz
BenQ XL2730Z - 27" 2560x1440 TN 144Hz FreeSync
BenQ ZOWIE XL2735 - 27" 2560x1440 TN 144Hz
BenQ XL2420Z - 24" 1920x1080 TN 144Hz
BenQ ZOWIE XL2411 - 24" 1920x1080 TN 144Hz
BenQ ZOWIE XL2430 - 24" 1920x1080 TN 144Hz
BenQ XL2720T - 27" 1920x1080 TN 120Hz
ecay
Thank you. I find the menu but there is no blur reduction option.There may be not some monitors may be.
Falkentyne
Ecay,
the blur reduction setting is in the SERVICE MENU. The service menu is: Power off, hold button #4 for 5 seconds, power on while holding button #4, then release.
Then press button 4 to enter the service menu.
The factory menu is buttons #3 and #4 held down. and then button #5 to enter.
razu1102xd
hello
I bought this monitor yesterday.
and i heard xl2540 has dyac mode(mbr).
is XL2546's Dyac and XL2540' mbr is completely same thing ?or is there difference ?
sry for bad english
sry for bad english
They are very close but not identical....razu1102xd wrote:is XL2546's Dyac and XL2540' mbr is completely same thing ?or is there difference ?
Generally speaking:
BenQ/Zowie DyAc -- official strobe mode enabled via main menus, usually is brighter (with voltage-boosting electronics).
BenQ/Zowie Blur Reduction -- unofficial strobe mode enabled by Service Menu. Not as bright.
Brutek_Vladimir
At
https://www.benq.com/en-au/support/down ... river.html
I fould this:
XL2540 RTD ISPTool
Is it possible we can upgrade XL2540 firmware now?
Or some benq employee just screw things?
I fould this:
XL2540 RTD ISPTool
