Because i get conflicting information about the Asus VG259Qm and the VG279QM, i'm launching a full investigation on this matter.
The information that i'm frequently getting is that @240hz, the VG259qm's OD 80 has too much inverse ghosting as opposed to VG279qm where it doesnt' have inverse ghosting. From my recollection, the VG279qm had slight inverse ghosting at around 2-3% and a 3.8 g2g average which is VERY good
so i took it upon myself and i will review the Asus VG259Qm, the
25" version. maybe the overdrive tuning is different in this model, who knows. But
there have been members here who claim that 80 OD is unplayable at 240hz because of inverse ghosting so that really piqued my interest.
unfortunately, you guys have to wait until june 8 since that's when my vg259qm will arrive. Obviously, this wont' be a full review where i measure the colors, ergonomics, picture quality, etc.
It's strictly peak performance and checking to see if there really is bad inverse ghosting @240hz on OD 80.
btw,
if i like the results, i intend to keep the monitor, a dual monitor setup with the msi mag251rx would be awesome. I miss gaming on 280 FPS on rocket league. I seriously doubt it's better than the MSI MAG251RX but then again, ppl also claimed that the 25" version has better colors, contrast ratios, and color uniformity.
6/8/2020 the 25" version of the asus vg259qm will be reviewed and results will be posted.
I really really assumed the 25" and the 27" version were the same exact MONITOR just different monitor sizes, but based off what i've seen; it seems like these two monitors are using a
totally different panel. Yes, they are both using the fast IPS AHVA AU Optronics panels but the 25" sometimes use the sister AHVA AU optronics panel where the contrast ratios, response times, color uniformity, and Overdrive tuning is different.
the naming of these monitors really threw me off. HAd they named the 25" 280hz monitor differently, it would've been easier to not assume that they were both the same exact panel but with different display sizes. The aw2720hf and the aw2521hf are two totally different panels with different overdrive tunings, contrast ratios, and response times.
