Firmware upgrade using Linux tool, requires no hardware
Re: Firmware upgrade using Linux tool, requires no hardware
Is it taking longer than it did the first time?
it takes around 10-15 minutes. I remember it seemed to take longer over VGA than it did over DVI (I used my radeon 290x dvi port since I have a 'legacy' bios (not UEFI) on my motherboard and it worked correctly twice in a row.
The XL2720Z v4 firmware has a hidden AMA low mode that the XL2420Z does not. If I had money I would buy another monitor and test if crossflashing would work, even if it complains about the EDID.
So, i guess there will be non Windows version doing this fw upgrade?
Gotta get my hands on a laptop to try this. Only have a gaming pc (gigabyte motherboard, radeon r9 290x graphics)
Seems like you can't fail this. Non completly brick screen from what i could read, yeah?
can't get it to work. trying to boot from a old laptop
syslinux 4.03
Error: no configuration file found
No DEFAULT or UI configuration directive found
tryed with Universal usb installer and unetbootin, using win10
syslinux 4.03
I have no idea what sysxxx is.
We use Ubuntu. If you follow the exact steps here, it will work.
Follow my EXACT instructions on this page and pay close attention to the comments.
http://forums.blurbusters.com/viewtopic ... &start=220
Falkentyne wrote:I have no idea what sysxxx is.
what am i suppose to read? thats the steps i did, if you read what i wrote
ubuntu-14.04.3-desktop-i386.iso
Sorry I've never seen such an error.
Can you even get to the Ubuntu desktop and open a terminal?
I don't know how to use Linux. I only follow the instructions given by others step by step, and did repeated flashes (4 total) with those instructions.
Edit* got it to work! installed the small version of Ubuntu from a 700mb cd and installed everything needed with internet connection.
Took me many hours, but i got it to V2. Thx!
Its like a new screen! wow. I was so close to selling this monitor before this update! i LOVE YOU!!!!
Hi guys i am just going to follow this guide. Have you got any advice for me? i have a nvidia gtx960 and a benq xl2411z v1, and i am going to use ubuntu 15.10.
Just use the steps at the bottom of page 23 over here, that I listed.
I haven't flashed since V5 was dumped for XL2720Z, but everything should still be working.
Thank you.Falkentyne wrote:Just use the steps at the bottom of page 23 over here, that I listed.
