No FPS gaming possible
Ghosty_Ind
Re: No FPS gaming possible
Post by Ghosty_Ind » 07 Sep 2025, 16:06
LaggyTyp wrote: ↑
07 Sep 2025, 16:04
None of my friends have such problems. These are gamers who even have pre-installed browsers on their pre-built PCs. Some even have multiple browsers installed.
No, no, no, that's not a solution.
For me, it's due to:
- Segment overload (especially upload)
- Jitter
- Hardware solution that bundles packets
A deadly poison.
Yes I agree.. Most of my friends do not have such problem too. If this works in your case also, we’ll then look for the root cause of this issue.
Just try it once and tell me what u see…
LaggyTyp
Post by LaggyTyp » 07 Sep 2025, 16:07
Fast traffic lights at motorway entrances can significantly improve traffic flow.
Here in Germany, there are traffic lights in problem areas that only let one car pass at a time. The light changes back and forth within 1-2 seconds.
That's happening here too! That's the problem.
The congestion sets in. The jitter sets in. The hardware starts to regulate, or rather regulates more harshly. Games run like garbage.
Ghosty_Ind
Post by Ghosty_Ind » 07 Sep 2025, 16:11
LaggyTyp wrote: ↑
07 Sep 2025, 16:07
You have two PCs right… I would advise to suggest to test it on one. Save your history and bookmarks in case you are worried about that. But I would suggest to give it a try once.
jvraz
Post by jvraz » 07 Sep 2025, 16:16
Ghosty_Ind wrote: ↑
07 Sep 2025, 16:11
LaggyTyp wrote: ↑
07 Sep 2025, 16:07
and which browser do you use that doesn't cause this problem?
Hyote
Post by Hyote » 07 Sep 2025, 16:41
Not like the Steam client uses Chromium anyways. This topic is getting out of hand.
pracc
Post by pracc » 07 Sep 2025, 18:02
Yes, it's 100% ISP related, like I said before. I have the same problem with Vodafone DOCSIS: massive variance in downstream latency (around 9 and 13 ms) and upstream latency (around 13 to 50 ms with jitters to 200 ms in the evening). This leads to complete desync, super bad hitreg, and strange recoil. This problem is much less around 3 to 6 AM and completely gone when I play in another area on FTTH. It's some kind of workaround that the upstream speeds are in the area of ​​the network agency's regulations. The insidious thing is that the scoreboard shows a normal ping. The jitter in the upload can only be seen with advanced tools or in CS2, which offers a good diagnosis.
-> In the former Unitymedia territory, there is no upstream segmentation, uploading has no overhead, and it impacts capacity daily. They have no other solution except with vast sums of money. Of course, they don't want to spend that. Thanks to the private market economy and too few competitors.
delve
Post by delve » 07 Sep 2025, 18:16
I have vodafone FTTH, same problem as on ADSL2+ and VDSL in the same location.
pracc
Post by pracc » 07 Sep 2025, 18:31
delve wrote: ↑
07 Sep 2025, 18:16
It could be the same technique. Read through dervu's pastebin on page 34. Which operator built the network? Is it GPON or AON? If it's GPON, do you know how it was split, 16, 32 or 64 users per fibre?
The good FTTH connection I played on was a 16 GPON split from Deutsche Glasfaser.
...or something completely different. In my case, the problem disappeared three towns away on an FTTH connection (not from Vodafone).
If the problem occurs at certain times of day, between 12 noon and 12 midnight, and improves late at night, it is almost certainly a network problem. If the problem persists, I would suggest it is a hardware issue, overclocking, timings, and so on.
LaggyTyp
Post by LaggyTyp » 08 Sep 2025, 15:38
I could well imagine that real-time jitter smoothing (packet by packet) could help or even solve the problem.
There is a router that can do this, but I don't know how well it does it.
danbmx
Post by danbmx » 08 Sep 2025, 17:17
Has anyone tried installing OpenWrt firmware and noticed a difference?
