nothing changes. Only 1 thing im need use optical converter, without it, my pppoe connection doesnt work. Something with negotiations.
No FPS gaming possible
donger
Re: No FPS gaming possible
just for the sake of sharing data, that's how it looks like on literally prefect fiber 1000/1000 connection. I have zero issues in games and obviously i am not downloading p0rn when playing...
Unreazz
Yes i did and there is Zero difference. Installed on my OpenWRT also UDP SPeeder. its BS. There is not single Advantage to have openwrt. I was even dump myself to import it so i bought a Router from the USA which had it allready preinstalled. its regardless
drosku
good peering from the isp way more imp than routing even depends how well ur data gets sent to the exchange for eg frankfurt get that ur game goes on easy mode ZzzZzz
1000WATT
just for the sake of sharing data, that's how it looks like on not literally good fiber 500/500 connection. I don't have any problems with games and downloading torrents doesn't affect my gaming experience.
Torrent at full speed, 2600 half-open tcp\udp connections. But all these screenshots are completely irrelevant to this topic.
donger
donger
Great so it's just another useless "test" spewing out random numbers. I don't have pingspikes or anything like that when gaming... even when downloading games and playing at the same time. Just like some other BS website rated my connection C lmao
1000WATT
You say you have no problems with your internet connection.
I didn't suggest you take this test.
How can it be useful to you if you don't have any problems?
It's like a healthy person walking into a cancer center and saying, "All your chemotherapy, radiation therapy, and pharmacy services are complete crap; they're useless because I'm healthy and I have no problems."
donger
i am gonna ignore your idiotic comparison1000WATT wrote: β01 Oct 2025, 07:19You say you have no problems with your internet connection.
This "tool" says i will have ping spikes, this doesn't happen. Another tool from this website says i have a C grade connection when in reality it's A+ in literally every real life scanario i used it for. Your "tools" are generating random numbers and are useless.
1000WATT
Judging by the post in which you state: I don't have pingspikes or anything like that when gaming... even when downloading games and playing at the same time.
Why then did you write earlier: I ofc don't game when downloading with 100% speed because that would just be idiotic
If you don't have any performance issues in games when using the channel at full speed, then why is it idiotic to do this?
There must be logic here, itβs a pity that I canβt understand it with my psychiatric deviations.
