Official Asus ROG Swift 360Hz PG259QN Owners Thread
Tenchi
Post by Tenchi » 12 Jun 2022, 15:42
Hello,
ASUS ROG Swift 360Hz PG259QNR
When i turn the monitor off the screen goes black but you can see slightly the browser window
and i can move it and the monitor shows it.. (when pc is on).
At the first moment i thougt it was a burning image into the display..
I reset the factory default too and use the original displayport cable.
Post by RealNC » 13 Jun 2022, 18:25
Tenchi wrote: ↑
12 Jun 2022, 15:42
That sounds like the monitor only turns off the backlight but leaves everything else on. That's just weird.
Tenchi
Post by Tenchi » 16 Jun 2022, 07:25
I activated the ERP S4+S5 in the bios of my Apex z690 -
first i thought it worked but sadly its not working.
You have to check and open for example paint or something to show a small white box.
and this white box you will see when you turn of the screen.
I unplug the power cable from the display but this wont help.
Tenchi
Post by Tenchi » 17 Jun 2022, 13:03
I replaced the Displayport cable, the power cable incl. adaptor (from another QNR screen) but this wont help.
I have to check if the screen has the same problem or not...
miky5368
Post by miky5368 » 22 Jun 2022, 18:03
What kind of overdrive mode I use on this monitor ? Normal or esports ?
Tenchi
Post by Tenchi » 22 Jun 2022, 23:10
for desktop i use sRGB Mode / for gaming racing mode.
miky5368
Post by miky5368 » 23 Jun 2022, 04:22
Tenchi wrote: ↑
22 Jun 2022, 23:10
Thanks, what is the differences about normal mode vs esports mode overdrive?
NessDan
Post by NessDan » 18 Aug 2022, 14:09
Hi, I own this monitor and a 6950XT
I'm seeing people saying you can overclock, even a 433hz overclock, but I'm having difficulty doing it. Using the AMD Custom Resolution tool, it shows an error right when the dialog appears AND if you try to change the resolution at all, it immediately becomes invalid (the only "valid" refresh rate is "200" in the software.
What other software could I use to overclock on an AMD Radeon system?
2022-08-18 15_06_08-AMD Software_ Adrenalin Edition.png (147.12 KiB) Viewed 8374 times
2022-08-18 15_05_54-AMD Software_ Adrenalin Edition.png (142.91 KiB) Viewed 8374 times
2022-08-18 15_06_24-AMD Software_ Adrenalin Edition.png (153.79 KiB) Viewed 8374 times
Kosvill
Post by Kosvill » 03 Jan 2023, 06:36
I did buy Asus XG249CM 270hz ROG. Is it normal that ROG series' joystick and buttons feels more loose and soft compared to VG259QM? Can anyone confirm this or are my buttons faulty?
