how i fixed the problem.
assombrosso
Re: how i fixed the problem.
Post by assombrosso » 30 Aug 2022, 03:04
Also, what games u play ? And what’s the difference in terms of KDR and how many multi kills and headshots you make ? In my case, when my system performed “better” my KDR goes wayy up and winning games becomes unreasonably easy. I would need the details of the change if you can shed more light into it, will be great.
woodyfly
Post by woodyfly » 01 Sep 2022, 06:35
u should make a tutorial on how to set up everything. if youve truly fixed it, you are basically a pioneer in this issue as nobody has really ever fixed it. I dont think anyones tried solar panels like you did
lyar
Post by lyar » 05 Sep 2022, 09:06
woodyfly wrote:
01 Sep 2022, 06:35
+1
Post by Chief Blur Buster » 05 Sep 2022, 16:36
lyar wrote:
05 Sep 2022, 09:06
+1
It'll only help a few people, but a few success reports have already been posted here by going offgrid (power stations, solar) in earlier threads.
woodyfly wrote:
01 Sep 2022, 06:35
The problem is the solution unique per person.
No two interefrence problems are perfectly identical, much like no two snowflakes are identical.
A univeral HOWTO, is thus impossible, and one can only attempt generalities that has better odds of fixing things.
calamity5555
Post by calamity5555 » 22 Sep 2022, 03:52
Hello Texre,
Glad you solved the issue for yourself. I'm looking to try a custom made power station with battery/inverter from a local provided in BC.
Since you're based in SoCal, have you tried playing Fortnite matches at localhost in Fullerton? https://goo.gl/maps/snyQBcH8q4VziMRt6
I have the same issue but I can't seem to get responsive, smooth, and accurate gameplay at any of the localhosts for tournaments.
However, I've heard good things about localhost Denver.
If you have time for the next 3 months, do you mind playing at localhost Fullerton for a bit to see if it's the same as a fixed setup.
wadge
Post by wadge » 28 Sep 2022, 08:29
calamity5555 wrote:
22 Sep 2022, 03:52
Hello Texre,
Give us any update when you tried the combo inverter (better be pure sine wave) and battery ;)
texre
Post by texre » 02 Oct 2022, 13:13
wadge wrote:
28 Sep 2022, 08:29
calamity5555 wrote:
22 Sep 2022, 03:52
Hello Texre,
Fullerton is about 40 mins from me
texre
Post by texre » 02 Oct 2022, 13:19
calamity5555 wrote:
22 Sep 2022, 03:52
Hello Texre,
Some interesting findings, after a few months of testing. It still works great I love gaming again I don’t rage at all anymore gaming sessions are so much more enjoyable it’s perfect. Soo about charging the station with electricity, Ik chief said electricity can’t be stored but it can. I charged with my bad electricity the gameplay becomes so bad. After I use all bad energy and charge only with solar it goes back to being really good. So it definitely can be stored. So I don’t think your inverter power station will work sadly. Only thing that works is solar for right now.
texre
Post by texre » 02 Oct 2022, 13:21
Can electricity be infected ? It’s not interference because I don’t play while it’s charging so it has to be like a bad energy source or something who knows
akylen
Post by akylen » 02 Oct 2022, 13:42
texre wrote:
02 Oct 2022, 13:21
Could you do a little tour with pictures of your setup/electricity setup to give us a view of what it looks like ?
